Help? Air Conditioning AND REDLINE AT 6500?
It might be a good idea to keep that tach under 6K with A/C. Back in 1970, I bought a new Z/28. Living in South Florida, I, and the sales manager tried everything to get it made with A/C....... GM refused. They said that the LT1 was proven to smoke A/C compressors at high rpm. After I got delivery of the car......I understood what they meant.
Gears
Someone told me that if you mark the inside of the rear tire and the half shaft at the same location, then rotate the tire forward one revolution counting the how many times the half shaft turns it would give you a rough idea of the gears. for instanse one revolution of the tire to 3 and a 1/2 revolutions of the half shaft would equal a 3.50 gear. Don't know how true this is?? Maybe a more experianced member will chime in and advise.
That works but it's easier to just get out and run about 50mph, get the rpm and find an online calculator. There's quite a few of them.
Rare as hens teeth. A friend has a 65 L76, with A/C, and looked for over a year for one for judging.......he never found one. LIC's does reproduce it, he bought it, and it passed judging.
Received 1,860 Likes
Nope. Midyears didn't use the "ratio tags" - they were only used on some C1's, and there's nothing stamped on the top of the midyear diff; the ratio codes and assembly date are stamped on the bottom of the diff housing, between the strut rod bracket and the spring retainer plate.
Nope, not on midyears. The only other solid-lifter Corvette with A/C was the '72 LT-1, and that application DID have a lower redline than it did without A/C, but the engines were identical - the idea was that the owner would respect the redline.
#33
