1960-61 top tank radiator value?
Former Vendor
I picked up an original top tank rad for 60-61 and was trying to find a value to list it at. I can't even find an original one for sale anywhere or one that has sold. Anyone have any ideas?
Used aluminum rads are tough to sell because it is hard to have them repaired. If you are trying to sell it. I would have it boiled out and pressure checked.
However, if you recently removed it from a car and it was functional, it has good value to a Bowtie/Survivor owner. But I'd have it tested as suggested. That'd help sell.
If it has the original side brackets and good shape, those are quite likely worth much more separately.
Rich
Received 1,859 Likes
That radiator is about 40 years past its projected design life, and it's not repairable; not something you'd want to put in a car that's supposed to be a reliable driver.
You might want to save the top tank, especially if it is a early one, w/o the ribs and the "sneak-a-peak" hole - although Tom is probably making those now. Early on, I had him transplant an original early tank to his radiator.
I bought one back in the 80's at the nationals in Williamsburg from a gentleman I believe was from Amityville NY for about $800 best as I can remember. We pressure tested it in the parking lot. It was still good 4 yrs later when I sold the car. Don't know if this helps.
