I have a 3731394 intake with the snowflake back by the distributor- right behind 2nd carb also there is no day or month casting under the heat shield- never seen on like this before and anyone else Thanks Rich
Yes I realize it is a 2nd design casting number- but unlike my other 56 intake this one has no date cast under the heat shield-and there are no grind marks- also the casting number between the carbs does not have a snowflake also no grind marks- there is a snowflake back by the distributor- I have never seen one with this combination quit odd I will try to load a photo of this later if I can figure it out- not very tech savoy wish me luck Rich M
Hello Richard,
Do you have a digital camera? If so, take a couple of photos of the intake and save it as jpeg files on your computer. Send me a PM (private message) and ask me how you can post your intake picture on this forum.
Richard
Hello Richard,
Richard
sorry it took me so long to get photos onto sight but I am not a computer person- As you can see there is no snowflake with the casting number but there is one back by the distributor area- I would put the photo of the underside but my patience is at an end and all it would show is a clean casting If anyone else has seen this- anomaly casting and has any information thanks Rich M
You did a good job. Now wait for someone to give their information on your intake manifold.
now that I have calmed down after my computer picture experience it came to me that possibly that this is a over the counter or warranty replacement piece run at a different time Rich M
There were lots of minor variations in the early Winters castings, but none of them were anything special or experimental; we see the same kind of variations in the early (Winters) fuel injection baseplate and plenum castings.
I have seen two others without dates but I have not seen a snowflake put in a different place on casting- at least I have a one off conversation piece- maybe it was someone's first day or a bad Monday I guess I have a one of one that no one will want except for a decoration to hang up and talk about Rich M
