Induction Systems
Old Apr 30, 2014 | 05:39 PM
65tripleblack's Avatar
65tripleblack
Default Induction Systems
Chrysler Corp cars used a Ram Air system and Chevrolet used a cowl induction system. Speculation or cold facts about how one affected torque and power versus the other.
Joe
Old Apr 30, 2014 | 07:08 PM
wilcar's Avatar
wilcar
I ran a new 76 Trans Am back in the day and with the factory sealed shaker scoop block off plate removed it ran a tenth quicker in the 1/4 with no other changes. Have been articles stating that the cooler denser outside air can increase performance.
Old Apr 30, 2014 | 09:11 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I have a fresh air induction on my '67 SB that I built. I draws air from the back of the BB hood, sometimes referred to as the cowl area. After installation, I did rejetting and timing adjustments, and then took my car back to the track. Previously I turned 13.6/104. With the new system, I could not keep the car from spinning well into 2nd gear. The increase in torque was very evident with 14.1/14.2 times. Based on this experience, my cowl area system works. If you go to my Album, I have two pictures of the engine side of it. Dennis
Old Apr 30, 2014 | 09:13 PM
JohnZ's Avatar
JohnZ
Joe
All factory "ram-air" systems are bogus advertising/marketing hype - none of them work; the intakes are located in the static boundary layer of air, so there's no "ram" effect until well over 100mph. That's why Pro Stock cars have the scoop intake 18" above the hood surface.
The Chevy systems emphasized two things - the high-pressure area at the base of the windshield, and cold air; there's about a 1% increase in power for each 10*F the intake air charge is below ambient underhood temperature. I don't think Chevy ever advertised "ram-air".
Old May 1, 2014 | 04:28 PM
63Corvette's Avatar
63Corvette
I agree with John, but the air cleaner on the mid year fuelies (and C1 airbox cars) certainly comes close
To Induction Systems
