cleaining the engine 1959 corvette HELP
Old May 6, 2014 | 07:16 PM
Dklean2003's Avatar
Dklean2003
Default cleaining the engine 1959 corvette HELP
Hello,
Going to take my 59 vette to a car show this weekend.
The judge last time said I lost BEST IN SHOW becasue my engine wasn't clean enough.
So this time I want to clean it.
I can wipe down most of the stuff but the engine block has some grease on it. If I can get that off should look good.
Any suggestions on how to do this? What would it use? Could it damage the orange paint on the engine?
Also what parts of the engine should I cover up to not get wet.
Thanks in advance,
Dean
Old May 6, 2014 | 07:25 PM
MikeM's Avatar
MikeM
Originally Posted by Dklean2003
Hello,
Thanks in advance,
Dean
Either leave the hood shut next time or if the judge gets too nosey, just slam the hood on his neck. You won't have any further problem out of him.
Old May 6, 2014 | 07:28 PM
66jack's Avatar
66jack
I use lots of simple green and lots of shop rags...
Old May 6, 2014 | 07:31 PM
Dklean2003's Avatar
Dklean2003
I agree. I had it closed. Not that it looked bad. As he was judging I said. Do you want to see the engine? He said sure so I opened it for him.
He then started chewing me out. I was scolded. He said : You just lost BEST IN SHOW' you need to clean your engine
I think he was thinking since the hood was down I was hiding something but I was not. I just like the cars with the hood down. I like looking at the lines.
Plus my engine is all original so I don't have the chrome stuff all over like some people.
Dean
Old May 6, 2014 | 07:38 PM
chris ritchie's Avatar
chris ritchie
There's engine cleaning products made specifically for this purpose. But I too prefer Simple Green. I use a toothbrush to scrub away at some of the nooks and crannies.
You don't need to cover anything unless you remove the air cleaner for better access. Then you should cover the open carburetor. Leave the distributor ignition shield on the protect the distributor. Wax the shielding and the air cleaner cover for a spiffy look. Don't forget the inner fenders and firewall.
Griot's makes a product to spray on newly washed engines to make them look spiffy. Don't know if it's any good. I've been reluctant to use it because I suspect it contains silicone, and I don't want that substance on my car.
Old May 6, 2014 | 09:13 PM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
Doesn't anybody steam clean anymore or am I showing my age?
Old May 6, 2014 | 09:18 PM
Dklean2003's Avatar
Dklean2003
Cool,
So you don't even spray your engine down with water.
Just simple green and a shop towel? Thats good on tough oil on engine block?
Old May 6, 2014 | 09:19 PM
Dklean2003's Avatar
Dklean2003
Cool, so simple green is good on tough oil stains on engine blocks?
Your saying to just spray, scrub, then remove with shop towels?
Thanks,
DEAN
Old May 6, 2014 | 09:43 PM
corvettekent's Avatar
corvettekent
2023 Corvette of the Year Finalist - Unmodified
2022 C1 of the Year Winner - Unmodified
Go to your auto body paint store or NAPA and buy some wax and grease remover, put it in a spray bottle and spray the grease away. I have been doing this on my '60 for 20 years. No brushing required. Simple Green may work just as well but I have never tried it.
Good luck on your next show,
Kent
Old May 6, 2014 | 11:20 PM
chris ritchie
Yes, Simple Green works great with a little scrubbing on tough oil stains. After scrubbing, I hose it off with water from a garden hose. I'm careful not to get too carried away with hosing down the engine.
Steam cleaning also works great. I don't know about those steam cleaning machines they sell for home use. I remember the steam cleaning ones at the self serve car wash. They were a combination of hot soapy water and high water pressure. The car wash didn't like you cleaning your engine. So you had to do it quick. If the high pressure and volume of water screwed up your car, then it wouldn't start, and you had no way to get home. Another problem is that when you cleaned the engine, it was still hot from driving to the car wash. Not a good idea to spray water on hot exhaust manifolds.
Old May 6, 2014 | 11:27 PM
mcb55-210's Avatar
mcb55-210
At first,I didn't read who wrote this...just reading the replies. Mike, you always make me laugh! I knew it was you!
Yes, Simple Green works great for degreasing, and REALLY great on white wall tires.
Mike
Old May 7, 2014 | 12:46 AM
ghostrider20's Avatar
ghostrider20
I would not get any cleaner or water on the alternator or distributor. Plastic grocery bags and rubber bands work well for protecting them. Some cleaners can discolor aluminum so there's that.
A hot soapy pressure washer would work great. I have used a real steam cleaner 200* hot water pressure washer with a dish soap feed and that really works great, but will lift any loose or brittle paint right off. I have never used it on vette engine but have used it other vehicles.
Old May 7, 2014 | 07:31 AM
MikeM's Avatar
MikeM
I sometimes flush and engine off with my hose hooked to the hot water heater in my garage. I also use the hot water hooked to my pressure washer and that works even better. Some pressure pumps don't like hot water though.
Old May 7, 2014 | 08:11 AM
Jhemp3's Avatar
Jhemp3
I've been using Simple Green for years and it's one of the really good cleaner/degreasers. A word of caution however, rinse well as it is corrosive to aluminum and will, after time, erode enamel paint. Not saying don't use it, great stuff but, from experience, rinse very well. I treat most cleaned surfaces with WD-40 or similar substance.
I understand the US military was using full-strength SG to clean helicopters because it cleaned them so well without any scrubbing until they found it was compromising aluminum structures. Probably an urban legend but makes good copy.
To cleaining the engine 1959 corvette HELP
