1958 upper control arm play
Old May 6, 2014 | 09:57 PM
wally3's Avatar
wally3
2nd Gear
Default 1958 upper control arm play
I have movement on the left upper control arm (inner front ).How do I fix this and what parts do I need Thanks
Old May 6, 2014 | 11:21 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
At the very least, the upper-inner shaft/bushings will need replacing (that is, if the play is at the upper-inner shaft area). But, if the play is at the upper-OUTER shaft, then that shaft/bushings will need replacing.
I put the following together several years ago, maybe this will provide you with some help and guidance.
http://www.chevytalk.org/fusionbb/sh...hp?tid/218134/
http://forums.corvetteforum.com/atta...om-parsons.pdf
Old May 7, 2014 | 05:20 AM
rich5962's Avatar
rich5962
Tom's the resident expert on these FE's and other stuff so follow his guide and you'll be in good hands.
Tom, I didn't know a PDF existed. Nice! Did DZVette convert?
I just downloaded a copy. Thanks.
Rich
Old May 7, 2014 | 09:27 AM
DZAUTO's Avatar
DZAUTO
Rich
Yes, Dave did that------------------------I don't have those kind of computer skills.
Old May 7, 2014 | 09:40 AM
Plasticman's Avatar
Plasticman
I had upper inner bushing threads in the control arm become worn / damaged, and the bushing was loose (to the control arm). Probably caused by improper bushing installation before my time....
Replacement of the control arm was required in my case.
Plasticman
Old May 7, 2014 | 01:16 PM
DZAUTO's Avatar
DZAUTO
Plasticman
UPPER A-FRAMES WITH ENLARGED BUSHING HOLES CAN BE SAVED!!!!!!!!!!!!!!!
Have a GOOD welder run beads around the ID of the hole. Then use a good carbide rotary file in a die grinder to trim (as needed) the welded hole.
Place the A-frame in a vice and USE AN OLD BUSHING TO RETURN THE THREADS. Then when the new bushing is installed, it will fit VERY tight.
Also, as always, remember that these parts (such as upper and lower A-frames) are the same as 49-54 passenger cars and they are cheaper when bought as a part for a pass can as opposed to a part for a Corvette (Corvette parts that are common with pass car parts are always priced 10 times higher!!!!!).
To 1958 upper control arm play
