Ground Strap Engine Mount ?
Old May 8, 2014 | 07:56 AM
Revfan's Avatar
Revfan
Default Ground Strap Engine Mount ?
Hey Guys
Just want some clearification
Where does the ground strap go? One end goes under where they words ground strap are in the photo... but does the other end bolt onto A or B (or some other location?)
I couldn't really tell from the AIM or other photos I have seen
Thanks!
Old May 8, 2014 | 08:00 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
It goes from that hole in the frame to what you have marked as B
Old May 8, 2014 | 08:23 AM
Revfan's Avatar
Revfan
Thanks!
Old May 8, 2014 | 09:10 AM
vark_wso's Avatar
vark_wso
Old May 8, 2014 | 09:59 AM
Velox's Avatar
Velox
No, it goes where he marked position A. Position B is the long bolt and would not provide a ground from frame to engine. Position A is a bolt from the engine block which would provide a ground to the frame. Note the frame mount has the star washer against the frame (under the strap)
Old May 8, 2014 | 12:38 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Attachment 47793134
Attachment 47793135
I agree, those are the CORRECT attachment points.
Old May 9, 2014 | 11:25 AM
Wayne1964's Avatar
Wayne1964
Clean to bare metal for good ground.
Old May 14, 2014 | 07:46 AM
Revfan's Avatar
Revfan
Ok... What is the secret?
I can't get wrench or socket/ratchet on that nut. Or, I can get the socket on, but then there is no clearance to get a 3/8 ratchet on the nut. Tried a flare/line wrench and can't get that on the engine mount bolt.
Am I missing a trick? Surely, I can't be the only one to have tried to replace the ground strap with the motor in place?
Old May 14, 2014 | 08:03 AM
Wayne1964's Avatar
Wayne1964
Maybe try 1/4 RATCHET EXTENSION ?
Old May 14, 2014 | 08:46 AM
Revfan's Avatar
Revfan
Wayne!
Thanks! I didn't have a 1/4 extension (I didn't have a 9/16 1/4" drive socket either)
BUT
Your suggestion caused me to dig through my tool box, and I found a 3/8" elbow, which made it all work!
Thanks guys... I LOVE this forum!
Old May 14, 2014 | 09:41 AM
ifitgoesfast's Avatar
ifitgoesfast
try a flare nut wrench
Old May 14, 2014 | 01:54 PM
Revfan's Avatar
Revfan
Actually, I tried a flare nut, but the flare was too thick to fit in there... I needed a thin walled socket and a universal joint
To Ground Strap Engine Mount ?
