Master Cylinder 63 STD
Trying to remove the front passenger brake hose and according to the shop manual, says to remove the double flare nut, then the u clip and then pull the brake hose out. Easy enough, grab my 3/8 flare/line wrench and try to turn the flare nut (counter-clockwise), nope , not budging. Put a little more muscle into it, and yep, it starts to round/strip. GREAT!!!!
It didn't really move much, so what are my options here??
1. Leave as is and worry about changing the hose at a later time?
2. Take some needle nose vise grips and try to turn it?
3. ???
I was hoping to change the hose, since I'm doing a full drums/shoes/springs change. But I think if I proceed and try to remove that flare nut, I could do some damage and the whole steel line to that front right wheel from the line splitter near the MC will have to be replaced, which doesn't look fun considering it's routing under the fan shroud.
Am I right in that the flare nut (to remove) should be turned counter-clockwise? Most likely yes, but thought I would ask.
Should I take the 5/8 open wrench and hold the brake hose nut under the bracket while I try to turn the flare nut?
Any sense in using something like WD 40 on it and let it sit for a day to try and loosen the bond?
When that happens, I get out the flame wrench and heat the flare fitting until it's red then put the flare wrench of the nut and easily back it off.
WD 40 is not a penetrating oil. Automatic transmission fluid, Marvel Mystery oil, diesel fuel are good. Or buy a commercial brand of penetrating oil. Some are good, some aren't.
And wouldn't you know it, I finally get around to opening the box of shoes and they gave my 3 longs and a short...
For those with the replacement MC's, how did you bench bleed them? The Raybestos unit I have, has 3 outlets and a bleeder valve (like the unit in FTF's pic in post 19). I'm guessing that bleeder valve is for bench bleeding the MC, but the instructions make no mention of it.
My thought process is to...
Attach some clear plastic tubing from the bleeder valve, close off the open port (the other two ports came plugged), fill the MC till about 1/4 from the top, put the end of the tubing into the reservoir and submerge into brake fluid, open the bleeder valve and activate the piston with a philips head screwdriver until there are no air pockets and resistance is felt.
Close the bleeder valve, install MC in firewall, remove cap from main out (some fluid will drip out, but as long as reservoir remains somewhat full, no air should be introduced, and hook up hard brake line.
Does that sound feasible?
Or do I need to leave the bleed valve alone and hook the tubing into the main outlet and bench bleed that way?
http://forums.corvetteforum.com/c1-a...der-screw.html
Hope this helps.
Freddie
Keep us informed.
Rene
So here's my new dilemma. I was going to just gravity bleed the brakes, since it's only me and right now I don't think 2 people would do any good.
See when I was replacing the front brakes, I disconnected the front right brake line and basically left it hanging while brake fluid dripped out and the old MC emptied. And really the brake line was dangling for days until I had time to get to it. So I think all the steel lines may have emptied. When I opened the bleeder on the right rear cylinder, nothing came out. And nothing is coming out. The MC is full and I've just left the bleed screw open.
Will the fluid eventually make its way back to the right rear bleed screw?
What are my options here if the whole system is empty, except for the MC?
Do I have to get one of those one handed pressure bleeders now to basically pull the brake fluid from the MC?
Would the 2 person job work (one person pumping, while I operate the bleeder screw, open on the way down, close before pedal goes all the way down, pedal back up, open bleed screw, pedal down, etc.)?
I don't think gravity is going to work in this case, is it?
I'd start with the left front wheel just to get things going quicker. Don't get in a hurry.
MikeM likes the gravity method - he may have some tips for you.
Starting in the right rear, the procedure was, open bleeder valve, pedal down, close bleeder valve before pedal bottoms out, release pedal, and repeat.
At first it was working, older/murky brownish fluid started coming out with some air bubbles here and there. I was able to get about 2 or 3 tablespoons out and then nothing was more was coming out. It would move maybe a mm and then nothing again. We did the pedal thing for about 50-75 reps and still nothing.
I'm now wondering if the MC is bad or something happened in the internal working of it. When I took the cap off to check the level, the fluid was murky (blackish murky, not brownish). I would have thought it should remain clear (new MC and new brake fluid) and I would just top off as it got low from bleeding.
But after trying to bleed for a while, the level never got lower and I noticed when you depressed the pedal, the fluid would kind of bubble up. Shouldn't the piston force the fluid into the steel line and not up into the reservoir?
I think it's time for the Motive PB, so I'll be putting in an order tomorrow.
Well I guess that will all be a mute point now, since I put in my order this morning for the Motive Power Bleeder....
Question for those that use the Motive Power Bleeder...is it necessary to still bench bleed a MC since you are now forcing, by pressure, brake fluid into the system through the MC? Wouldn't the pressure fill all the voids and push any air out through the bleeders?
If you can't get fluid flowing, loosen the line just below the MC and let it gravity bleed out. That'll put a little fluid tension on the system and start it bleeding.
