frame cracks?
Old May 22, 2014 | 08:09 PM
67ermineconvert's Avatar
67ermineconvert
Default frame cracks?
hi guys are there any common frame cracking or weld stress cracking areas on the 67 convert frame? i have what i would term small previous repaired ares in what i would describe the front frame around the swell for the coil spring on the outboard side of the frame between the curve and the firewall . on the passenger side it looks like two older unrepaired cracks on the underside of the opening for the coil spring . sorry for the lack of pics. can i assume there is some twisting in that area where the crossmember meets the frame? thanks Peter
Old May 22, 2014 | 08:13 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Sounds like someone ran into to many curbs in its life
Old May 22, 2014 | 08:41 PM
MikeM's Avatar
MikeM
There are some areas mentioned in the Chevy Performance book of several years past that mention areas close to what you are talking about. The Chevy book talks about reinforcing in that area for racing. I'd suppose that is areas of high stress.
Old May 23, 2014 | 05:56 AM
tbarb's Avatar
tbarb
Can you see if the metal had been pulled out some where the strap down holes are along both sides of the frame? If so, the frame has been pulled because of accident and has suffered some damage. Those crossmembers are strong but the weak point is where the frame bends in and up forward of the firewall.
Old May 23, 2014 | 07:37 AM
chrislyn's Avatar
chrislyn
The area that you have described is a stress zone ( coil spring ) this is a common area to have cracks. Over the years I may have welded about a dozen spring area's . Not hard to do just need to remove the spring ,drill a small hole at the end of the crack v the crack and weld ,grind it flush and refinish the frame area. Put it back together. The other crack that you speak about could be from previous damage or could also be stress.
Old May 23, 2014 | 07:51 AM
67*427's Avatar
67*427
When I bought my '67 many years ago.... about 1973 or 4 as I recall, the entire cross member under the engine was broken away from the frame on the passenger side. The factory welds were split right through the middle. The only thing holding the front end together was the engine! Driving the car home after purchase was a real adventure. The torque of the 427 would make the car head for the ditch of you got on it at all. We pulled the engine, used a comealong to pull the frame back together and the cracks all closed up completely. Welded the frame and reinforced it and it's been fine ever since.
Old May 23, 2014 | 05:38 PM
67ermineconvert
thanks guys i will drive it a bit this summer and will be pulling the motor and front suspension out over the winter anyway so i will pull bang and weld it up. that engine crossmember getting loose i would say mine is on its way to that and it doesnt look like it would be hard to twist those things loose after 40 plus yrs.
Old May 23, 2014 | 07:28 PM
DansYellow66's Avatar
DansYellow66
I don't remember all the details but there were actually two methods of fitting the frame parts around the front spring pockets for welding over the years. One of the methods was more prone to stress cracks and metal fatigue than the other method. But stress fractures in that area are not rare but the fix is simply to prepare the weld area and weld them up. There have been some magazine articles written on the subject - JohnZ may have authored one - not sure.
Old May 23, 2014 | 07:59 PM
jdk971's Avatar
jdk971
had the same thing on a 63 coupe. found out when it could not be aligned. welded up and everything is fine. jim
Old May 24, 2014 | 08:22 AM
Avispa's Avatar
Avispa
Both my 65 and 66 big blocks developed the same crack under the passenger side front spring pocket. My 66 has a converted 70 frame, so it'd probably safe to assume this is a common problem with old, metal fatigued frames. If you develop a crack in any area near the mounting points for the front suspension you may even notice the engine twisting while viewing from the passenger compartment while turning the steering wheel back and forth. That is how I noticed the crack on my 65.
It just was a freak coincidence that the crack on my 65 developed when I got a new set of tires put on the car. It drove perfectly until I got the new tires, but afterward would pull to the left HARD under acceleration. Took me two years to figure that one out. I keep my eyes on the frame these days.
Old May 24, 2014 | 06:30 PM
67ermineconvert
funny i put new tires on and happened to be turning the wheel back and forth and thats when i noticed the motor moving.
To frame cracks?
