Re-assembly Sequence for a C2 Suggestions
Old May 23, 2014 | 03:22 AM
Revfan's Avatar
Revfan
Default Re-assembly Sequence for a C2 Suggestions
Since project creep got a hold of me, I am sure I didn't take em' apart in the most logical order, but I am coming down the home stretch.
What order makes the most sense/easiest to reassemble?
Side Pipes
Inner Splash Shields
Outter Splash shields
Battery/Battery Mount & Tray
Thanks!
Old May 23, 2014 | 09:20 AM
65hihp's Avatar
65hihp
However re. 4: install mount and tray before installing battery.
Old May 23, 2014 | 09:41 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Originally Posted by 65hihp
4, 3, 2, 1
Dennis
Old May 23, 2014 | 05:37 PM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
#4 and #1 in that order. Forget the splash shields. They'll just make the cabin hotter by holding the heat in the engine compartment.
Old May 24, 2014 | 02:55 AM
TCracingCA's Avatar
TCracingCA
Default You mean that you forgot Rule #1 to write it down as you disassembled??
Oh Boy! Your in trouble!!!!!!
To Re-assembly Sequence for a C2 Suggestions
