1958 Ignition Switch Lock Problem
Old May 25, 2014 | 09:16 AM
Dads58Vette's Avatar
Dads58Vette
Default 1958 Ignition Switch Lock Problem
I am trying to find any information that well help me diagnose (and repair) a problem with the ignition switch. The switch will not turn all the way left to the "Lock" position. This effectively makes it so a key is not needed to start the car (obviously not a good thing). I have not been able to find anything that explains what the problem might be or what solution I should pursue. Does the whole switch need replaced or is there something else that I could try?
Old May 25, 2014 | 10:59 AM
5869vette's Avatar
5869vette
Sounds like you may have the wrong key.
Will this key unlock your doors, trunk and glove box?
Good luck
Tony
Old May 25, 2014 | 11:57 AM
Dads58Vette
Good luck
Tony
The keys do work in all the other locks.
To 1958 Ignition Switch Lock Problem
