engien
Old Jun 7, 2014 | 05:33 PM
1958Chris's Avatar
1958Chris
7th Gear
Default engien
How to take paint off a motor
Old Jun 7, 2014 | 05:37 PM
66jack's Avatar
66jack
Is the engine in the car or out
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Is your engine assembled?
Old Jun 7, 2014 | 05:40 PM
1958Chris's Avatar
1958Chris
7th Gear
Default engien
It is out of the car
1958Chris's Avatar
1958Chris
7th Gear
out of the car
1958Chris's Avatar
1958Chris
7th Gear
Yes it is assembled
Old Jun 7, 2014 | 05:50 PM
ghostrider20's Avatar
ghostrider20
Is it assembled and ready to be installed? Do you just want to paint the engine?
Pressure washer
Scotchbrite pad
Air driven wire wheel
Carb Cleaner
Paint Thinner
Old Jun 7, 2014 | 05:52 PM
1958Chris's Avatar
1958Chris
7th Gear
Pressure washer
Scotchbrite pad
Carb Cleaner
Paint Thinner
Ok do those work great
Old Jun 7, 2014 | 05:53 PM
1958Chris's Avatar
1958Chris
7th Gear
Pressure washer
Scotchbrite pad
Carb Cleaner
Paint Thinner
Ok do those work great yes it is ready to install
66jack's Avatar
66jack
Take off carb, leave dist on, leave exhaust manifolds on and tape up all the 'holes' with duct tape...spray with paint remover...wash off...repaint if you want...
Old Jun 7, 2014 | 05:56 PM
1958Chris's Avatar
1958Chris
7th Gear
Ok i will try that.
What is the best paint remover
Old Jun 7, 2014 | 06:01 PM
ghostrider20
Depends on how much you have to do? Is the engine oily? You have to get the engine CLEAN and paint-less for your new paint to adhere and look good.
I would use some type of paint remover (Thinner, Mineral Spirits etc), and a plastic brush and scotchbrite pads to get the engine clean. Then rinse clean with pressure washer (Hot water). When dry, spray with siphon fed alcohol and wipe it down until you feel it is clean and moisture free.
Then paint. READ the directions on the paint can.
It should be obvious, but you need to tape, plug, protect any area you do not want water, solvents or paint.
Mark
To engien
