Anyone tried the #392020 gauge for 65-67 cars, from corvette central? As far as Number color and Font size? Thanks Ron B.
I may be misunderstanding your question, but if you're looking for correct, the right 65 and 66 (at least) gauge says "battery" and -40 on the left and +40 on the right. The one mentioned says "volts" and 8-18.
It also says it won't work with factory wiring. Are you putting an LS engine in a midyear? More info would be helpful. The color and font look correct if you're doing it for that reason.
Wiring is not the issue. It is the fact that the letters and numerals are a mint green. Mine seem more white. I have 2 cars one with a restored cluster, it looks more white also. The word volts also seem taller, than the word battery. Just wondering if anyone had the same experience. Thanks for your reply. Ron B.
