Oil pan
Jun 11, 2014 | 11:04 PM
Oil pan
On a 66 corvette 327/350hp , to remove the oil pan does the transmission and the clutch need to be dropped? Thanks in advance
Jun 11, 2014 | 11:08 PM
NO...you need to drop the steering linkage and the dust shield on the bell housing..plus the Starter to get to the pan bolts...
Jun 11, 2014 | 11:11 PM
Thank you for the advice 66 jack
Jun 12, 2014 | 12:37 AM
Remove the two bolts holding the idler arm to the frame on the passenger's side. That'll move the steering linkage far enough out of the way. Remove the dust cover and starter as stated above. Removing the oil filter will make life easier as well. Then you should be able to remove the pan bolts and drop the pan right out.
If you're not deeply into originality, a Fel-pro one-piece pan gasket will make installation much easier.
Jun 12, 2014 | 12:55 AM
If your not time pressed, drop the oil and let it drain for a day or two.
Jun 12, 2014 | 02:14 AM
Make sure you measure the pan so you'll install the correct gasket.
Jun 12, 2014 | 07:58 AM
C2 of Year Finalist (track prepared) 2019
Quote:
Originally Posted by
ghostrider20
Hmmmmm....... I'm curious, why?
Jun 12, 2014 | 08:57 AM
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Oil pan
jim lockwood
So you don't take a bath working under the car after the pan is off !!!
Jun 12, 2014 | 11:52 AM
rongold
I think you'll be surprised by the amount of oil which will drip from the engine and the span of time over which it will drip.
Last summer the oil pan was off the engine in my '60 for about three weeks. The engine
-->never<-- stopped dripping.
Jim
Jun 12, 2014 | 12:18 PM
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
You dont need to remove the starter.....
I second the one piece rubber gasket.
Jun 12, 2014 | 03:21 PM
rongold
See post #9.
Jun 12, 2014 | 03:34 PM
St. Jude Donor '07
jim lockwood
See post #9.
especially if you start the engine before removing the pan......
Bill
