Exhaust Manifold Gaskets?
Exhaust manifold followup queston
I just saw this old thread and I'm working on the same thing on my 66 (SB 327)...I'm replacing some old worn out Headers a previous owner had put on with the original Rams Horn Exhaust Manifolds. Do you typically put any type of high temp sealant or do you simply bolt on metal to metal?
(It appeared that when the Headers were put on some type of sealant was used in the past)
thanks
thanks
You might want to put a straight edge across your cast iron exhaust manifolds first and if they seem to be straight and no corrosion showing, you might get by. If not, use the gaskets.
Mike T - Prescott AZ
