Electrical Issue
I drove it down the road about a mile and when turning onto a side road, the car shut off again. I wiggled the cables and after a few tries power came back and I drove it home. I left the car running while wiggling all the electrical wires I could find and could not get it to shut off. I checked battery cables for any place that was bare and maybe ground out but they look good. With the car running I removed the positive lead to make sure the alternator would keep the car going... no problem there.
I noticed tat when the clutch was pressed, it would move the wiring harness that comes down from the steering column. to be safe I tied the harness back. I drove the car for over an hour and can no get it to shut down.
Does anyone have any ideas of what could cause this? or what else I can check? I did replace the ignition switch about two years ago.
The main harness plug is of a rather lousy design and is the culprit...it works loose and the car shuts off completely. Others have figured out a work around to avoid the intermittent issue but I can't speak intelligently to this fix.
I replaced the under hood wiring harness and managed to break the retaining clip on the main harness plug to the firewall
. I used wire ties to help keep the plug in place but I am sure I will have the same problem at some point. Gotta love 40yr old technology...
Cheers,
Frank
Once I got it home is when I checked all other wires.
I reached under the dash and tried moving the ignition switch wires but still could not get it to shut down.
Gravity caused this problem ,New ignition switch fixed.
If you were working around the radiator, there at the horn relay there is a black wire with a terminal at the buss bar. The black wire is a high temperature insulation covered 16G fusible link. The other end is a spade terminal rubber covered plug which connects to it's mating rubber plug terminal to the 12G Red wire in the forward harness which feeds the entire car through that bulkhead connector.
I'd recommend that you check that buss bar area for corrosion or loose connections in the link terminals since you were around it working on the rad. A few weeks ago someone forced a dead short under their dash Brown ACC wire plug to Cluster ground and blew that fusible link. The entire car shut down, except the horns, as those are fed from the buss bar directly. if it was pre '67, it would have fried his harness.
There isn't a good pictorial of this wiring in the '67 AIM, I believe because the forward harness and Horn Rely arrived as an assembly with the wires and fusible link already connected.
Also below. The original wiring diagrams of the buss bar connections were wrong, showing a visual/phisical connection of the 12v feed directly to ground. This causing some innocent pre-'67 re-wirers in the past to burn up their harnesses.
Rich
Rich
I've been working on a charging problem for a few days now and while looking at the 67 AIM, I could not fathom why the output of the alternator went directly to ground on the horn relay. The AIM manuals should come with a list of corrections/changes.
Rich
Rich
