Plug wire routing?
Old Jul 16, 2014 | 10:51 PM
Mike Geary's Avatar
Mike Geary
Originally Posted by Robert Lewis
That's a great tip, thanks! I did notice the numbers, but on one of mine it reads "42 R 68" and, turning it upside down, "73 L 15".
What the heck does that mean?
Install the grommet on the left side of the motor (driver's) with the L up. Wire 7 is outboard, 3, 1 and 5 in the inboard position.
Passenger side (R up), wire #8 is outboard, etc.
Old Jul 16, 2014 | 10:57 PM
Robert Lewis's Avatar
Robert Lewis
Wow! Another mystery solved. Thanks, Mike!
Old Oct 24, 2014 | 03:19 PM
Robert Lewis
Mike,
I'm finally getting to the installation. Forgive my ignorance, but if the grommet is on the left/driver's side of the engine stamped 7315, the only wires on the left side are 1, 2,3, and 4. How could you put the #7 cylinder plug wire on the LEFT side of the engine?
Signed,
Stupid in SC
Old Oct 24, 2014 | 03:25 PM
Robert Lewis
Wires # 1, 2 & 3 should be 48-49"
Wire # 4 is 45"
Above data is from a number of sources I've saved over the years, including Lectric Limited.
And yes, feeding the wires backwards through the motor mounts is the secret.
Mike
Mike,
What are the lengths for wires #5, 6, 7,and 8?
Old Oct 24, 2014 | 03:27 PM
JohnZ's Avatar
JohnZ
Mike,
Signed,
Stupid in SC
That's where the #7 wire belongs.
The cylinders are numbered (front to rear) 1-3-5-7 on the driver's side, and 2-4-6-8 on the passenger side. Firing order is 1-8-4-3-6-5-7-2.
Old Oct 24, 2014 | 03:39 PM
Robert Lewis
Wow, do I feel stupid. Thanks, John. So when Mike refers to "Wires # 1, 2 & 3 should be 48-49", Wire # 4 is 45" - he means the first cylinder driver's side (#1); first cylinder passenger side (#2); second cylinder driver's side (#3); second cylinder passenger side (#4), right?
That means that 3 of the remaining 4 are at 29" (on my set) and the fourth 27" one is probably #8, correct?https://www.corvetteforum.com/forums...ies/crazy2.gif
Old Oct 24, 2014 | 03:48 PM
JohnZ's Avatar
JohnZ
Right.
#1-2-3 are 48"-49"
#4 is 45"
#5 & #6 are 32"
#7 is 28"
#8 is 26".
Old Oct 24, 2014 | 03:52 PM
Robert Lewis
Right.
#1-2-3 are 48"-49"
#4 is 45"
#5 & #6 are 32"
#7 is 28"
#8 is 26".
Thanks, John, for being patient with the Village Idiot.
