1967 327 Engine Code help
I have a 1967 327 engine block with the suffix V0228HT.
Per this number the engine came out of a 1967 327 4BC 4SPD 350 HP
The number in front of this is a 113444 which I take is the production sequence.
I am trying to verify if my research is correct?
Can anyone help me?
thank you
Can anyone help me?
thank you
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,357 Likes
Moving from Parts For Sale classifieds to General discussion area.
Can anyone help me?
thank you
Can anyone help me?
thank you
HT 1965 327 s h/p, hyd lift, m/t 350 4 Vette
HT 1966 327 s h/p, hyd lift, m/t 350 4 Vette
HT 1967 327 s h/p, hyd lift, m/t 350 4 Vette
HT 1969 350 manual trans. 255 4 full size
V0228HT
V - Flint Assembly Plant
02 - Month, February
28 - Day, 28th
You need the casting date on the bellhousing flange behind the distributor to know more.
113444 could be a 1967 Corvette serial 13,444. Or it could have been added by someone restoring your car since they had a -HT engine.
Can anyone help me?
thank you
Can anyone help me?
thank you
Mike
That sequence # (partial vin) should have a 7 in front of it if it's a 67
Still should have a 7 at the beginning of the partial vin on the pad.
Received 1,859 Likes
Received 1,283 Likes
If it is a 1967 Corvette engine.
HT - 1967 Corvette, 327, 350 hp, manual trans
HT - 1968 Corvette, 327, 350 hp, manual trans
HT - 1969 Passenger Car, 350, 255 hp, manual trans
Original Poster, could you post a picture of the engine front pad, and also the casting number and casting date of the engine block.
And it looks like his first post was the only post made by the OP. We may never get the full story.
