C2 firewall connector
Has only one tried to replace the plastic housing only on the engine side firewall connector? Mine has a damaged loop at the top preventing it from latching securely. Do the wires and "bobby pin" connectors remove from the back of the housing? I was hoping to reuse my existing wires and just replace the housing without splicing any wires.
Randy
Randy
Make sure to keep the wire orientations correct.
Someone may have a picture to show you what the individual connectors look like. The archives may also have pics. Or try an Google "Packard Electric wire connectors"….or something similar. A few places still have them for sale, if needed.
Larry
EDIT: Checkout this earlier post from the archives: http://forums.corvetteforum.com/c1-a...ctor-pins.html
Larry
Randy
You could also use soldered butt splice and heat shrink wrap to do a wire join.
In the case of the "Red" wire inspect the plastic housing for that pin and make sure it is not melted. Common problem. I was able to fix mine with some JB weld years ago.
Mark
I mounted the panel gently in a padded vise to hold it while I pushed up the wire, installed the tool and then pulled down to remove the connector.
Joe
http://www.ebay.com/itm/Lisle-56500-Terminal-Tool-/331266737029?hash=item4d21094385&item=331266737029&pt=Motors_Automotive_Tools&vxp=mtr
Joe
http://www.ebay.com/itm/Lisle-56500-..._Tools&vxp=mtr
Randy
Joe
Thanks for the tip. I went out and bought one yesterday to put in the tool drawer. You never know when it might be needed. You can never have too many tools…..although I am getting close
Larry
