Greasing u-joint question
Old Aug 17, 2014 | 08:33 PM
Tossin's Avatar
Tossin
Default Greasing u-joint question
After a really productive weekend removing the sombrero bushings (5lb sledge and lots of penetrating oil) and rear shocks (sawzall through bolt that was mounted backwards before the body was dropped), I'm to the point of reassembling the rear end of my '65.
I'm putting new u-joints (without grease fittings) in all around - should I shove a little grease in the cups around the needle bearings just to be safe, or should they be fine as they are?
Thanks!
Old Aug 17, 2014 | 08:35 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Should be fine just they way they are.
Old Aug 17, 2014 | 08:36 PM
66jack's Avatar
66jack
They should be fine...
Old Aug 17, 2014 | 09:06 PM
Tossin's Avatar
Tossin
Great! Thanks. Sorry if it was a really basic or stupid question, but I wasn't sure.
Old Aug 17, 2014 | 09:33 PM
DomL64's Avatar
DomL64
Is is better to get the ones without the grease fittings or the ones with them ?
Old Aug 17, 2014 | 09:38 PM
Nowhere Man
Your original non greese-able kind lasted this long didn't it?
To Greasing u-joint question
