Heater Core Fail
Old Aug 23, 2014 | 09:14 AM
Jefjak's Avatar
Jefjak
Default Heater Core Fail
1965 327/365
My heater core failed. I am going to bypass it for now and replace sometime in the future. I have read the various posts about the "heater delete" setup and want to go this route. However the bolt for the 5/8" hose fitting is frozen in the intake and won't budge. Can I put a cap/ clamp on the 5/8" hose fitting as it exits the intake, similar to the cap/ clamp on the 3/4" tee at the expansion tank? Or is the pressure too great for that?
Thanks in advance!
Old Aug 23, 2014 | 09:33 AM
65 vette dude's Avatar
65 vette dude
Why don't you put one of those heater hose shut off valves on the 5/8" hose that feeds the heater core? I think both NAPA, and Home Depot sells them.
Old Aug 23, 2014 | 11:21 AM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I have mine bypassed with a short hose, from 'send' to 'return'.
Heater core is on order .. but project creep is already well established!
I have read that it's possible to trap air if you just cap it... but no first hand experience with that.
Old Aug 23, 2014 | 11:22 AM
toms silver 60's Avatar
toms silver 60
Just cut the hoses and plug them off for now. Research the best ways to loosen up your fitting. If I remember right, the one using candle wax worked surprisingly well.
Guess you might use a heater more up there than down here in FL..
Old Aug 23, 2014 | 01:00 PM
Jefjak's Avatar
Jefjak
I haven't read that about trapping air. Seems the situation would be the same whether capped or plugged w/ a bolt like the factory "heater delete" option. I had mine bypassed by connecting the hoses but it doesn't look pretty, so I decided to go this route. I don't really need the heater - don't drive it in the winter. So my initial question is just wondering if the cap/ clamp can withstand the pressure of the system. I have it hooked up that way now - I'll drive it a while and see how it holds up. Thanks for your responses.
Old Aug 23, 2014 | 02:50 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
It will hold especially well because the bolt has threads.
Old Aug 23, 2014 | 03:52 PM
JohnZ's Avatar
JohnZ
Originally Posted by Jefjak
1965 327/365
My heater core failed. I am going to bypass it for now and replace sometime in the future. Can I put a cap/ clamp on the 5/8" hose fitting as it exits the intake, similar to the cap/ clamp on the 3/4" tee at the expansion tank?
Yes, you can - the pressure is the same throughout the system; a cap and clamp will work fine.
Old Aug 23, 2014 | 04:07 PM
Jefjak's Avatar
Jefjak
Thank you all for your input!
Old Aug 23, 2014 | 11:26 PM
63redvette's Avatar
63redvette
St. Jude Donor '14
Yeah, no need for that heater here in FLA...can I use that valve thingy to stop flow to heater? I don't want to drain heater hoses for fear that our wonderful FLA rust gremlins will attack my heater core. (NOT trying to hijack thread, I promise. Just asking.)
Old Aug 24, 2014 | 09:08 AM
watson's Avatar
watson
This is a bit off topic, but you may want to be aware of it. A buddy of mine who owns an auto parts store recently told me that he has seen a large number of new heater cores that leak. When I asked a mechanic friend, he said the same thing. I was going to put a new core in my 65 project just because I am already there. Now I plan to have the new core tested by a radiator shop before I button it up. The core is a pain in the rear to change after everything is back together.
Doc
Old Aug 24, 2014 | 09:11 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Doc
Always a good idea.
Old Aug 24, 2014 | 09:15 AM
Jefjak's Avatar
Jefjak
Yes, you can use the shutoff valve to stop flow to the heater. Search and read the past posts on this so you put the valves in the right location.
I have also read that the new cores may leak, and many suggest doing a pressure test on them before installation. Also need to be careful during install to not break the solder joints, and not to crush the copper lead pipes on the core by over-tightening the hose clamps.
To Heater Core Fail
