Windshield Problem
I have tried to adjust the latches to they just barely clasp without rattle
The windshield is new bought on ebay
probably a mistake not buying from a well known supplier
is it possible my windshield is not correct width or height
all comments appreciated,,, even the ones telling me to buy from respected supplier
Thx
Steve
My only guess is that the windshield you purchased is not the correct shape and may be too narrow.
Art Bruns
Art Bruns
yes,,, i had very good instructions and it went together nicely,, even putting it back on the car it went smoothly
I have been using the hardtop because my convertible top is not installed yet
I thought it might be to narrow,, but no way of telling for sure
not immediately... but over a short period of time
when i bought the car a year and a half ago,,, the windshield was cracked in the curve on the passenger side and had to be replaced
If i could find a 61-62 close enough it would be nice to fit my hard top on a different car... although it would be tough to believe its the top
do you happen to know the remedy for the soft top pulling the frame off the glass
I would think the solution might be the same
Look down on the windshield header and you will notice that the passenger side pin hole for the top is slotted and the driver's side is not. Don't laugh you'd be surprised how many owners don't realize this.
You should always latch the driver's side first as this 'indexes' the top and then the passenger side and then tighten the rear bolts JUST ENOUGH for the weather stripping to meet the deck lid. Do not tighten those bolts down like there is no tomorrow. If that doesn't work then you need to look hard at your windshield install.
There are rubber gaskets under each end of the windshield at the bottom just forward of the door. Removing 1 or 2 of those could tilt the windshield back to make the H/T latch easier but then you have to deal with the door post alignment and fit of the lower windshield frame to the cowl area. Its all a compromise. I have heard of glass being made too 'short' for the frame as well. Perhaps somebody can give you some measurements off an original piece.
How does the soft top fit/latch ?
If you put the H/T on and wind up the windows all the way up how do they fit ?
Were the tabs on the windshield pillars strengthened when you had the frame off (see picture)?
If so then the frame won't have any 'give' like it did with broken tabs....
When done fitting the hardtop then adjust the soft top frame to fit the windshield , side windows and where the rear bow meets the deck lid.
Then have the soft top installed on the frame, not to tight , not to loose. Correct installation of the soft top is very important as it can shrink over time and create problems.
My 62 is a hardtop only so I don't have the soft top shrinkage problems.
My 57 has a soft top and I always leave the top up to keep it's shape, except when we go out driving the car. I never store it down.
Bruce B
I did not notice the oval hole for the latch pin on passenger side,,, but i know it now
the tabs were ok(but probably weak)
when i pull the windshield again i will have the tabs repaired
I only installed 1 rubber gasket on each side
It would nice to know the actual measurement of the glass ,, maybe the width some place in the middle or where the pillars end just before the start of the curve
I did not have a method of installing the hard top,,, but i think i always snapped the latches last,,, i also tightened the deck lid bolts along with the side bolts pretty tight
when i remove the windshield again to check the tabs... i will the follow your method to fasten the hardtop
Thx
Steve
1
60
