Broken Bolt
Old Sep 7, 2014 | 09:49 AM
Jefjak's Avatar
Jefjak
Default Broken Bolt
Car is a '65 327/365
The long bolt that secure the crankcase vent tube assembly at the rear of the block has sheared off flush w/ the top of the threaded hole. There is nothing to "grab" to remove it, so tried a bolt extractor. No luck - just can't get a good grip on the extractor due to it being down in the ventilation hole.
So I guess my only option is to try to drill it out. Does anyone know if the hole it threads into bottoms out, and how deep? Or is it a "through" hole? If so, any danger of the metal shavings ending up where I don't want them?
Any other suggestions? Thanks!
Old Sep 7, 2014 | 10:12 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I'm not sure of the answer to your first question. When you drill coat the area with some grease and also the bit, it will collect the metal shavings. Dennis
Old Sep 7, 2014 | 11:15 AM
66since71's Avatar
66since71
Same thing happened to me 40 years ago... I wound up swapping the 300 HP motor for an L-79 CE crate motor!
I've wondered often about how I would have extracted the remaining bolt. I think I'd have had a sleeve made for a pilot drill. Centering the drill is the hard part. Id make the OD same as vent hole, ID to match the pilot drill. In the years between I've seen drills that are designed to cut turning left vs right to extract broken bolts. I'd try one of them with the bushing.
Good luck... I hope your fix is cheaper than mine was
Harry
Old Sep 7, 2014 | 11:33 AM
wonderful's Avatar
wonderful
Man! Don't you just hate it when that happens. First, I would center punch the sheared bolt (try to get the center as close as possible). Put some grease on the sheared bolt to catch all the filings. Drill out the bolt with a proper sized cobalt drill bit. I find that cobalt drill bits are the strongest. After completion, re-tap the hole. GOOD LUCK.
PS: Drilling out sheared bolts is one of my worst jobs to do.
Old Sep 7, 2014 | 11:40 AM
62vetteman's Avatar
62vetteman
That is a blind hole. IIRC if you keep drilling it would go into the bellhousing area. The 327 block that is going in my '62 has the exact same problem. I was going to have my brother ( tool and die maker ) make a drill bushing. The top of the remaining bolt is most likely not flat and would cause the drill to go off center. The odds are against you in trying to get the drill centered on a 1/4-20 bolt size in a hole that is a couple of inches down. My plan is to use a left hand drill bit with the bushing like Harry said.
Erich
P.S. I was also going to put two threaded holes in the bushing so that it can be pulled out.
Old Sep 7, 2014 | 04:57 PM
PattiR's Avatar
PattiR
You might try to rotate the broken end of the bolt with a sharp drift or a punch. I know this sounds weird, but call me an I'll explain it over the phone. I have had bolts broken off shear and have been able, with patience, rotate them out of the block w/o any problems. (taught to me by my neighbor, a super mechanic!)
Dennis 979-224-4245
Old Sep 7, 2014 | 05:32 PM
Jefjak's Avatar
Jefjak
Thanks for the suggestions, everyone. I think I'll try making a "bushing" to drill it out. I'm not a machinist, but do have woodworking tools. I found that a piece of wooden clothes hanger rod is exactly 1-1/4" diameter and fits snugly in the hole. So I'm going to make something w/ that and w/ a hole in the center as a drill guide.
Question: do I want to drill a 1/4" hole, then re-thread? Or do I want to drill smaller, like 7/32" then run a tap to clean the threads?
Dennis - thanks for the offer to call. If my bushing isn't turning out right I'll give you a call.
Old Sep 7, 2014 | 06:31 PM
Mike Smith's Avatar
Mike Smith
Dennis 979-224-4245
Try this first - it is your least risky option, and you have nothing to lose but a little time. I've backed out oil pan bolts this way with an ice pick.
Old Sep 7, 2014 | 06:54 PM
MikeM's Avatar
MikeM
There is an easy way and a hard way. Take the easy way until you decide to pull the intake off or remove the engine from the car.
Old Sep 7, 2014 | 07:07 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Either do like Mike says, or use a push in grommet setup with a hose to the PCV. Easy, cheap, and won't risk any shaving trashing your motor. When you rebuild it one day you can do it right.
Old Sep 7, 2014 | 07:34 PM
out2kayak's Avatar
out2kayak
Something to consider is getting a left handed (i.e. reverse) drill bit smaller than the bolt -- leave sufficient meat on the bolt so as to not bugger up the threads. Using tape, mark off the maximum depth that the bit should go. If you have a new bolt, the depth is easily determined by something less than the full length of the bolt.
Gently drill out the center of the bolt. In order to ensure the bit does not walk on you, use a center punch to put a divot into the bolt.
If the bolt is rusted, soak it in the appropriate penetrating oil (or 50/50 mix of acetone and ATF) overnight.
Using a bolt extractor that will reach a minimum of 1/2 the drill depth freely, insert and lightly tap with a small hammer. All you are trying to do is get a bite in the metal over a good surface area to transfer the torque necessary to remove the bolt.
Slowly and gently rotate the extractor to remove the bolt.
I have done this many, many times with success. Just take your time, drill squarely, and be patient.
After, chase the threads with a tap before replacing the bolt.
-- Joe
Old Sep 7, 2014 | 10:25 PM
Ron Miller's Avatar
Ron Miller
This is a fairly common problem around farming country, probably also common anywhere old cars are involved. Here, we usually get a person with welding experience who will lay a nut on top of the broken bolt and weld the nut to the bolt. The heat from the welding operation, along with a little penetrating oil and judicious use of a wrench will usually back the broken fastener out.
I'd recommend checking around, find someone who has had some experience along this line, and give it a try. Almost always works, is a lot quicker and easier than trying to drill and tap the broken stud out. I've got one I've got to do in an intake manifold as soon as time permits.
Old Sep 8, 2014 | 07:34 AM
66since71's Avatar
66since71
The problem with this bolt is that it's a very small 1/4" diameter, 2" down inside a dark 1.25" diameter hole. It's almost impossible to see, much less get at!
Harry
Old Sep 8, 2014 | 07:54 AM
Jefjak's Avatar
Jefjak
Harry
That is exactly the challenge. I'm all for trying easy first and have given this a lot of thought over the past week. I like Mike's idea of a Molly, but not much to grip. A large enough anchor w/ one "wing" in the crankcase hole may hold. I will try Dennis' method w/ a punch or ice pick first, but again the problem is that there's not much room to maneuver or to get leverage.
I've already gone thru the process w/ a left hand drill bit and extractor, and per my initial post just can't get a good grip on the extractor - the end is actually below the top of the 2" deep hole. Combined w/ the fact that the bolt is in pretty tight, it hasn't budged.
One thought I had was forget the fastener and use sealant to hold it down - needs to be able to withstand the heat though. Is there such a product?
Old Sep 8, 2014 | 08:21 AM
Tyler Townsley's Avatar
Tyler Townsley
Use a heli coil that way you do not have to worry about the threads just use the bit for the heli coil to drill it out thread it then insert the heli coil. NOT a fun job.
Tyler
Old Sep 8, 2014 | 08:31 AM
Mr D.'s Avatar
Mr D.
I'm in the Mike and Tyler camp, pull the engine and drill out briken bolt than repair with heli coil.
Old Sep 8, 2014 | 09:01 AM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
Jefjak,
I feel your pain. I've been running my 327 after rebuild with this EXACT problem. Discovered this sheared flush with the block bolt AFTER the motor was in the car...this was back in '08. Well, 6 years and 25K miles later, I've been living with it by using silicone around the flange of the pipe to keep it in place. Do periodically re-seal this. That pipe 'ain't going any where when you hook it up to your aircleaner. Still functions as it should.
Yup, when the motor is pulled I will fix it correctly. It just ain't worth the hastle to fix her right in the car.
Again, I've had no issues and she functions correctly.
Good luck in your decision.
Jim
In God We Trust!
To Broken Bolt
Old Sep 8, 2014 | 09:10 AM
al89's Avatar
al89
this is the way I always remove broken bolts
Old Sep 9, 2014 | 07:56 AM
Ron Miller's Avatar
Ron Miller
Harry
OK, sorry I didn't pick up on your problem initially. I'd probably go with MikeM's fix until such time as the engine is pulled and it can be removed properly. Good Luck!
Old Sep 9, 2014 | 08:52 AM
mashinter's Avatar
mashinter
It is a blind hole. I get 1.21 and 1.25 deep on '58 and '59 blocks.
