Alternator arms?
Alternator arms?
This doesn't look right, anybody have an idea why double arms were used on this? On a NOM, 180 block cast number.
Are the support arms supposed to be bent, see anything else that looks wrong?
Received 1,860 Likes
[QUOTE=BANG11;1587794454
Are the support arms supposed to be bent, see anything else that looks wrong?[/QUOTE]
That's not a '63-'67 alternator mounting - note the black cast iron lower mount that's bolted to an accessory hole in the front of the cylinder head; those heads and that mount didn't show up until 1969. That's some kind of Bubba arrangement on a Heinz 57 motor.
Heinz 57 is an understatement
I'm changing the intake to an aluminum one, trying to follow your "intake swap" article as best I can. I'm going to leave the Bubba fix for now, make changes as winter projects.
Exhaust riser, how much movement is there supposed to be with the lever doing it manually? I think mine might be stuck.
Received 7,083 Likes
2015 C2 of Year Finalist
As you turn the spring damper the valve in the inside should move at the same time
You can keep the lower bracket and just get a upper bracket for a A/C car with the alternator on the left side. It will mount on the water pump bolt up to the back side of the alternator housing mount tab. It looks like yours in in front of the alternator housing mount tab. It will not be factory correct but it will work. Good Luck.
Is it supposed to be on the RH side? I have some 65 low hp motor stuff, maybe I could make it right.
Thanks for the replies
The lower alternator bracket mounts to the exhaust manifold. It is a different lower bracket than the one you have. Also I believe only A/C cars had the alternator on the drivers side of the car.
The car has been converted to sidepipes, all sidepipes were 2" correct? So that means I have 2" exhaust manifolds?
Almost forgot, here's the new addition
PS. Nice looking car
66's had 2" exhaust manifold outlets. You need a 3846559 exhaust manifold, and it will accept the production '66-'67 LH alternator lower and upper mountings ('66-'67 small-blocks all had the alternator on the left side, as did all '63-'65 small-blocks with A/C).
Thanks John, I thought the alternator moved sides after 65 but didn't know 66's went to all 2" manifolds.
Another problem I think I may have is my harmonic balancer is barely pushed up on the crank.
How far up on the crank is it supposed to go? I have almost exactly 1" of balancer hanging off of crank. I'm thinking I should remove balancer, clean, oil, and reinstall balancer?
