Crank Pulley
Old Sep 14, 2014 | 08:58 PM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Default Crank Pulley
I need ideas to solve a problem. I'm planning to install Steeroids power steering to my '60 283 4BL Corvette. The installation calls for a 2 groove crank pulley, the inner groove to run the water pump and generator, the outer groove to run the P/S pump.
My engine has a "narrow" (thin) balancer so my existing crank pulley has what I describe as a bell to space it away from the balancer and align with the water pump and generator.
Most small blocks have a wide balancer so changing the pulley wouldn't be a problem as it would bolt flush. My options are:
  • 1) find a 2 groove balancer with a bell that will keep the first groove the same distance it currently is from the balancer.
  • 2) Get an approximately 3/4 inch spacer between a new 2 groove pulley and the ballancer to bring the first groove out where it need to be,
  • 3) tack weld another pulley to my existing pulley.
  • 4) Least desirable is replace the narrow balancer with the thicker one and just bolt my 2 groove pulley to it.
  • Give me some good ideas or if you have a part number for a 2 groove pulley that moves the first groove forward of the balancer, that would be ideal
Captain Bud
Old Sep 14, 2014 | 09:02 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
GM made add on steel out PS pulleys for all SB and BB. They bolt on top the crank pulley.
