Crash!
First drive down Texas Rd in Old Bridge, NJ swerved to miss a deer and "kissed" the guardrail. All the damage was cosmetic. Drives like nothing happened. The impact from the guardrail missed the suspension, sidepipes, and wheels.
Hagerty appraisal is $19,365, although the body shop says they will probably need another 5K once they get into the work. They will be replacing the door. Since the whole car is being painted, decided to have a big block hood added without the strip package.
Shop says 2-3 months, so I'll double that and hope to be driving springtime next year. Couldn't wait to drive the Vette when I got it back from Corvette Paramedics and now it's gone again. One short drive in a year is just killing me. Just blessed I didn't total the car or kill myself.
http://s1283.photobucket.com/user/fo...?sort=3&page=1
Would make me sick, in fact, I am sick looking over the damaged area. Glad you were not hurt in that avoidance accident. I know instinctively one wants to steer away from a collision. Just thinking out loud here, since it was a deer, an "object" that's moving, just wonder if the damage would have been lessened to just hit the deer. At least it would be a moving collision rather than a tree or immovable object. Probably not since the guardrail served as a glancing blow and allowed the car to continue moving to absorb the energy.
At least the shop "knows" the car (smile). I'm with you, add another 2-3 months to their guestimate. Definitely keep Hagerty in the know regarding any up charges the shop identifies.
Good luck in this repair.
Jim
In God We Trust!
Glad you were not hurt. Hope you like the new hood.
We were actually lucky, as I've seen several other deer/vehicle encounters and it never fails to amaze me at how much damage a deer can do to a car.
The engine pulls cleanly from idle to redline. The powerband has moved up the rev range, and I'm happy to say it's still pulling strong at the top end and doesn't fall off as quickly as before. The electric choke that comes with the L-79 option makes the start up and subsequent miles much smoother that the manual choke setup from the stock carb.
The Tremec trans was very "notchy" and difficult to shift while driving home from Corvette Paramedics. 5th gear was especially hard to engage smoothly. I did notice a considerable improvement in shifting as the few miles I drove before the accident were put on the trans.
Of course the biggest difference from the previous set up was the drop in rpms at cruising speed. The car originally had a close ratio 4spd Muncie and 4.11 gears that had the engine turning in the 3,800-3,900 rpm range at 70+- mph. The new setup was apx. 2000 rpms at 60 mph with the 4.11's. For me, it's the perfect setup for around town and cruising the highway. The speedo cable that American Powertrain provided in their kit to mate to the new Tremec seized on the way home from the shop and they provided a replacement in a few days.
The other work at Corvette Paramedics involved a complete suspension rebuild, including new Bilstein shocks, rebuilt rear control arms, rear leaf spring, and front end components. They also replaced the original side pipes with Allen's "Super Quiet Side Pipes". The original pipes no longer had any baffle material, essentially a straight thru pipe, and they were extremely loud. Now they are very mellow at cruising speed and loud enough for me when the pedal hits the floorboard.
After the rebuild, I spent the next 3 weeks installing a new interior, including Hush Mat, underlayment, carpet, door panels, headliner, sun visors, and refurbished/rebuilt seats in leather with the optional headrests from Al Knoch. Along with the seats, I installed new shoulder set belts, and a new Freeman teak steering wheel. Prior to all this work, I installed power brakes which is another story all its own. I also pulled the gauge cluster, clock, glove box and steering column and sent them to Rick's Restoration and Larry's steering column service in Texas. The both did excellent work, with a quick turnaround and reasonable pricing.
Thanks to all for the kinds words about my accident. Driving in this area of NJ at dusk is a constant reminder about the large deer population we have in one of the most densely populated state in USA.
The Hagerty appraiser said it was best I missed the deer, since hitting the front end on our car usually means a total loss. The Vette's unique front end styling tends to clip the deer at the legs and send it up over the hood and into the cockpit. The appraiser has seen several examples of this happening over the years and it's not pretty for the deer or occupants. As many have said it's a blessing I wasn't hurt and the car will be fixed. With a new paint job and BB hood, I'll patiently wait another 6 months to enjoy a truly remarkable car that I am proud to own.
Years ago I saw a 63 which had some damage on the front. The owner said he hit an empty box at 55 and it did the damage. I could not believe it then again I was not driving...
A few weeks ago I hit a raccoon with my wife's car. Missed the first two then hit the last one on a busy freeway. It broke the front bumper and lower molding including the plastic underneath the car.
