1967 big block hood scoop place
What is the scoop right place in the 1967 big block hood.
Which has the measurements from the hood front line to the scoop front line(grille), how high is the grill opening/hole and and how long is the rear edge(Lip) from the the hood back line (of the crossing) ? Sorry my english.
Location: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
[QUOTE=kenba;1587842416]What are you trying to do build a BB hood from scratch or convert a SB hood? I suggest you don't do either & find a factory or repo. one.[/QUOTE
Yes, I try make the BB hood. I have 1965 hood and scoop, hood has already been destroyed, big hole in the middle of the hood. I found good instructions from the net and I want to try out how it works, first.
If I lived in America, I would buy a new finished, but the freight to Finland/Europe to pay as much as the hood.
So, I am only need the dimension get the scoop in the right place ?
A man must do what a man must do
http://www.up22.com/ScoopInstall.htm#Scoop installation
Here's a post that might be of some help to you:
https://www.corvetteforum.com/forums...ipe-specs.html
Thanks waynec, I really needed also the stripe specs, but these specs do not tell the Scoop place.
