Look for a kit that results in zero or very little offset or you will get wheel rub on your fenders .
Also if you have stock steel wheels on your '64 you probably will not be able to use later Corvette stock disc brake parts.
I had good luck with ABS Power Brakes kit. There are several good ones; check out some of the old threads.
Reason: Pronoun error
VBS had no issue bought kit with new spindles, knock offs work fine, then later installed all four disk brakes went to Bairs for trailing arms, Good luck do a search lots of info.
