Timing question
Old Oct 11, 2014 | 08:31 PM
prestige6's Avatar
prestige6
Default Timing question
If I were off one tooth when I installed the dist. and I have it as far as it will go to retard at 12 degrees.Without removing the dist.would I have to move the wires clockwise or counter clockwise???To obtain the correct timing at 8 degrees????
Old Oct 11, 2014 | 08:47 PM
JohnZ's Avatar
JohnZ
Why not just re-stab the distributor correctly? Only takes a couple of minutes.
Old Oct 11, 2014 | 09:03 PM
prestige6's Avatar
prestige6
Not on a 427-435 with all the shielding and wire grounds..
Old Oct 12, 2014 | 01:12 AM
LB66383's Avatar
LB66383
You need to move the wires one hole counterclockwise. That should advance the timing too far, and then you can turn the distributor clockwise to get your timing in spec.
Old Oct 12, 2014 | 01:26 AM
LT1driver's Avatar
LT1driver
I agree with JohnZ, do it right and it isn't that hard to do it right. get it right then put the shielding on. choice is yours.
Old Oct 12, 2014 | 08:44 AM
prestige6's Avatar
prestige6
This is the way I got it and all the shielding is on.
Old Oct 12, 2014 | 09:17 AM
Avispa's Avatar
Avispa
You may be having some trouble getting the distributor in the correct position because your oil pump drive slot was moved when the distributor was pulled. If you're off one tooth advanced, try moving the oil pump a little bit clockwise with a long screwdriver or an oil pump priming tool. It is possible to pull the distributor with the wire braid lugs still connected to the distributor shield support brackets.
Old Oct 12, 2014 | 09:22 AM
jerrybramlett's Avatar
jerrybramlett
Default I doubt you can get there that way.
Moving the wires effectively rotates the distributor 45 degrees. Moving the distributor one tooth on the cam rotates it ~28 degrees (I think). Both of these steps might rotate the distributor too far. You may have to remove the distributor bottom gear and rotate it 180 degrees. That will effectively rotate the distributor ~14 degrees.
Old Oct 12, 2014 | 12:44 PM
65tripleblack's Avatar
65tripleblack
There are 13 teeth on the driven gear.
Distributor degrees x 2 = crank degrees
Rotate wire one tower:
720/8 = 90 crank degrees
Move distributor 1 tooth:
720/13 = 55 crank degrees
Rotate dist driven gear 180 degrees:
[720/13]/2 = 27.5 crank degrees
Old Oct 12, 2014 | 12:59 PM
bluzrocker's Avatar
bluzrocker
Default dizzy position
I had similar problem...could not get the 8* desired....vacume pod was in contact with shielding...easy solution move dizzy one tooth...8* is a important number at least on my L71...moved it one tooth and it didn't drop all the way ...simlly bump the starter and VIOLA...now at 8* it idles at 750 rpm and shuts off and starts right up...shielding looks good but there are inherient problems....shorting out at coil wire and top shielding cover..cutting wire at bottom of shielding..need some edge protection there .holds in heat.
I have rechromed shielding but after initinal installation,(coill bracket was not letting coil go down far enough and shorting problems I left it off for now...agree w/ John Z
Old Oct 14, 2014 | 12:42 PM
prestige6's Avatar
prestige6
I did the same thing,but I had to remove all the shielding and the grounds. Timing is set at 8 degrees. Now to tackle putting the shielding back on which is a BIG PITA..
To Timing question
