Opinions on these C1/C2 for sale
https://buffalo.craigslist.org/cto/d...746265562.html
1965 corvette stingray coupe #matching 327CI 300hp 4 speed w/Aluminum knock off wheels & gold line tires. 2017 completely rebuilt engine. engine compartment refreshed to stock specs and shielding & air cleaner correct. Older Silver pearl repaint excellent condition shows well good clean lines with an excellent bird cage Chrome and stainless are in good condition. The frame is solid rust free The car was just inspected on 05//08/2024. Oil change, lube and test driven by mechanic . Vehicle is in excellent mechanical condition and passed New York State inspection.
1965 Corvette Coupe - $69,000 (Lockport)
Ted
marshal135 (05-14-2024)
https://longisland.craigslist.org/ct...747604234.html
1963 Corvette Coupe project car for sale.This is probably a good donor car for a restomod project. Car sat for a long period of time. Has some rust holes on birdcage around left side lower windshield and upper B pillars. Had an Ecklers nose put on some time ago. No motor or transmission. Frame appears to be from a 67. Rear fiberglass appears to be un hit and original as well as the doors, firewall and floors. Lots of trim pieces but not all.
1963 Corvette Split Window Coupe - $75,000
https://seattle.craigslist.org/see/c...747760397.html
1967 Chevrolet Corvette Coupe
1967 Chevrolet Corvette Coupe - $88,950 (Edmonds)
- Super rare last year, matching numbers
- 327 c.i. 300 h.p., auto, A/C, P.S. P.D.B.
- Matching transmission & rear end
- Beautiful rallye red with white interior
- Rebuilt engine, no rust (California/Nevada car)
- Cast aluminum wheels, 205-75-15 redlines
- Original bonding strips, rare tank sticker
- Two owner car, 1 of 224 (300 h.p. auto, air)
- V.I.N. 194377S117184
- Stock # 25779
- 49,764 miles
- $88,950
That is the ultimate mid-year cruser . Nice car as long as the birdcage and innards check out. Reasonable price too .
https://phoenix.craigslist.org/evl/c...747479742.html
VERY NICE 65 CORVETTE 4 SPEED SIDE PIPES TWO TOPS P/S P/B 327/300 HP MATCHING NUMBERS MAY TRADE FOR ((( 308 FERRARI OR NSX ONLY ))) CAN TRADE UP OR DOWN
1965 CORVETTE TRADE - $75,000 (Mesa)
https://dallas.craigslist.org/dal/ct...748051976.html
1965 Corvette Restomod Stingray Coupe 350 V8 5-Speed Manual Video
Corvette Stingray Restomod coupe modified between 2012 and 2015 with 16K miles on the restore. Summit Racing 350 cid with a Tremec 5-speed tranny, Hurst shifter, Positrac rear end, Torq Thrust 17” wheels, and four-wheel disc brakes, Features include custom interior with ZR1 C4-sourced seats, Vintage Air conditioning, Dakota Digital instruments, Kenwood amplifier, and Kicker audio with Bluetooth connectivity and sub woofer. 17000.00 body and paint in GM Sunset orange metallic.
Trim Tag
65 347 – coupe
420AA – Saddle vinyl
S3327 – St. Louis Body
900GG – Glenn Green Paint
Odometer 16041
VIN 194375S118578
Car is located in McKinney Texas
VIDEO HERE:
Drive Line:
• Summit Racing 290 HP Long Block 350cid installed in 2014 described as a GMPP 350, part number NAL 12499529, 4 bolt main, aluminum pistons, mild hydraulic cam, equipped with an Edelbrock Performer 2101 intake and Holley 1761 carb, aluminum radiator
• Tremec TKO 5 speed transmission with Hurst shifter installed in 2018
• High flow aluminum radiator with puller fan
• Stock, Positrac rear end with full independent stock front and rear suspension, springs replaced in 2017
• The American Racing Torq Thrust 17″ wheels are mounted with 215/45 front and 225/55 rear Uniroyal Tiger Paw tires
• 4 wheel disc brakes
Body:
• The fiberglass body is refinished in Sunset Metallic Orange, and the emblems and front chrome bumpers were removed. A couple of small blemishes can be seen. 17000.00 body and paint work.
• Features include a stinger-style hood, steel rocker panels, 1966-style grille, tinted glass, fender vents, and dual side mirrors
• Electric flip-up headlights
• Windshield wipers do not work, but all mechanics are there including washer lines
• Windshield has a small chip
• Does not have a spare
• There is undercarriage rust as well as undercoating
Interior:
• Custom interior includes high back bucket seats sourced from a ZR1 Corvette with coordinating Lloyd floor mats, carpet and door trim
• Custom wood grain trimmed dash, center console and steering wheel
• Dakota Digital instrumentation consists of a 160-speedometer, tach, and auxiliary gauges
• Vintage A/C is cold
• 5 speed Hurst shifter and carbon fiber ****
• Kenwood amplifier, and Kicker audio with Bluetooth connectivity and sub woofer
• Original AM/FM stereo does not work
• Custom magnets were installed on the sides of the seats to secure the ends of the seatbelts when not in use.
• Cabin air ventilator operational
• Custom cup holder included not pictured
1965 Corvette Restomod Stingray Coupe 350 V8 5-Speed Manual - $69,900 (DALLAS)
Trim Tag
65 347 – coupe
Odometer 16041
VIN 194375S118578
VIDEO HERE:
Drive Line:
Body:
Interior:
https://newjersey.craigslist.org/cto...748894368.html
1965 Chevrolet Corvette 31000 original Miles. Approximately 2000 miles ago work was done on the car. A brand new ZZ4 Crate engine (355HP with 405 pounds of torque) was installed with a new holly carburetor and an HEI Distributor. The original Muncie Transmission was rebuilt and installed. A new Ron Davis radiator was installed. All the bushings for the suspension and body were replaced with polyurethane bushings. The interior carpet was replaced. The original 327/300 engine was rebuilt and place in the crate which the ZZ4 came in the machine shop work for the block and heads were done by Haledon automotive in Haledon N.J. The engine will run on pump gas no need to add lead to the fuel. I have all the original parts needed to bring the car back to factory correct. Please leave your name and number and I will get back to you, serious buyer only please do not wast my time or yours. Local sale only car will not be shipped. Thank You
1965 Corvette Coupe extra engine - $78,000 (North jersey)
IMCO the above '65's stance is way too high and spare tire carrier missing doesn't help the appearance.
The following 3 users liked this post by 3JsVette:
https://pensacola.craigslist.org/cto...749347889.html
A 1965 corvette stingray in great condition for sale. This car has only had two owners has been garage kept and has air conditioning.
Please reach out with any questions and I will get back to you
65 corvette stingray - $55,000 (Baker)
I'm not really sure on the above '65 but the paint is bubbling and the interior needs work so maybe it's priced to try to sell quick?
I would need most of another 50 grand to straighten it out ,
Saw two on Hemmings:
https://www.hemmings.com/auction/196...c872bca4a80da6
https://www.hemmings.com/listing/196...b422c69fbcd4cc
They both look like nice cars.
Cheers!
Cheers!
https://seattle.craigslist.org/see/c...750916741.html
1965 Corvette. 327 365 HP. (L76) Solid lifter, 4 SP., 3:55 Rear End, Milano Maroon Metallic with maroon interior, (very rare). 1965 is the only year for maroon interior. Always garaged. 102 K.Aluminum knock offs. This car is in excellent condition. (198 points out of 200 at all corvette car shows.)
( Same owner for 39 years. Driven 29k miles in the 39 years.)
All awards and memorabilia in the garage goes with Car, ( see photos ). (It's a 10, Must see to appreciate.)
Asking $90,000.00 or best offer. Only serious buyers need to Call.
Corvette - $90,000 (Hoodsport)
https://slo.craigslist.org/cto/d/tem...750536091.html
1966 Corvette convertible small block 327, Munci 4 speed transmission . Black interior. in Great shape .email will get you more pictures and information. Serious buyers only. no test drives .
1966 Corvette - $63,000 (SLO county)
https://sfbay.craigslist.org/sby/cto...750632252.html
FOR SALE: 1965 Corvette Convertible. Rally Red 77K miles.Numbers matching 327/350HP 4spd, power steering, 355 Posi rear. Recent restoration with over $72K in parts alone, with receipts. Car is in EXCELLENT condition. All new or refurbished parts including New leather seats, TOP, carpet, and door panels. All guages rebuilt and work to include the radio and electric clock. Glass in perfect condition. Wilwood brakes. Engine recently rebuilt, New exhaust and engine chrome ignition shielding in excellent condition. Recent ceramic coating so paint and chrome are flawless. Car comes with three sets of wheels: Rally wheels, knockoffs, and original steelies. Underneath as clean as on top. Always garaged and covered. Cover included. Absolutely no joy rides. Come with intention to buy with cash or bank cashier’s check, read the Hagerty valuation. Get wife's approval first. Wont find a nicer one below $100K. Corvette guys will appreciate this car.
Car is priced at $63,500 FIRM. No trades. Car is located in the Sierra Foothills. Serious buyers only.
Reply via email if interested and include contact number.
1965 Corvette - $63,500 (sunnyvale)
https://milwaukee.craigslist.org/cto...747182148.html
Nice clean rust free 1965 Corvette Convert. Black with Red interior 327 4-speed runs out good needs nothing but a driver. Will consider another classic plus cash. call Don
1965 CORVETTE CONVERTIBLE - $75,000 (Antioch)
I think the above '65 has been posted before a while back.
Not much of a description for a C2 that "needs nothing but a driver".
https://buffalo.craigslist.org/cto/d...748716463.html
Listing this car for a friend who dosen't have internet
1965 corvette convertible
2 tops
White convertible top needs rear window
Hard top good condition
Fresh out of storage over 30 years
Numbers matching 327 4 speed
Rebuilt
Checked lacquer paint.
Original Interior with leather seats added
Door panels very good shape
After market stereo and equalizer works
Drives excellent
Couple hundred miles since rebuilt
All gauges work
Very good glass
Original transmission will go with the car but needs to be rebuilt
Side pipe car
48,500 cash. Or reasonably close offer
1965 corvette convertible - $48,500 (RANSOMVILLE)
2 tops
Rebuilt
Drives excellent
All gauges work
Very good glass
Side pipe car
