Transistor Ignition Coding
Old Oct 30, 2014 | 10:16 AM
ranger725's Avatar
ranger725
Default Transistor Ignition Coding
Was any special coding placed on the engine pad for '66 L36 motors with the K66 TI option?
Old Oct 30, 2014 | 10:50 AM
Velox's Avatar
Velox
No. Suffix codes were different if the 390 car had K19 & 4-speed (code IM), or powerglide (code IQ) or K19 & powerglide (code IR).
Old Oct 30, 2014 | 04:11 PM
JohnZ's Avatar
JohnZ
No. Reason being that up until 1966, T.I. engines had a unique suffix due to their unique engine plant-installed distributor; starting in 1966, when K66 (T.I.) was specified, St. Louis removed the standard points distributor and installed a T.I. distributor in its place, so the unique-to-T.I. suffix was no longer needed.
Old Oct 30, 2014 | 07:25 PM
ranger725's Avatar
ranger725
Thank you so much. I got bad information and started thinking I had a serious problem with my engine pad information.
To Transistor Ignition Coding
