Help Needed - Installing Trailing Arm to Leaf Spring
Old Nov 6, 2014 | 07:52 PM
JohnFerguson's Avatar
JohnFerguson
Default Help Needed - Installing Trailing Arm to Leaf Spring
Yiikes - doing a body off restoration and just rebuilt the trailing arms. Trying to figure out the best way to re- install with the body off. There is a lot of energy in that leaf spring and I can see that it could certainly injure if not careful - especially with no weight in the back end of the car.
Old Nov 6, 2014 | 08:25 PM
Boyan's Avatar
Boyan
Use a ratcheting strap over the upper frame ceoss member, that way it pulls the leaf spring up.
Boyan
Old Nov 6, 2014 | 08:50 PM
66jack's Avatar
66jack
This is how i did mine..Small floor jack a towel and some webbing with some vise grips..
Old Nov 8, 2014 | 07:49 AM
JohnFerguson
VeryHelpful - thanks a bunch!
Old Nov 8, 2014 | 04:20 PM
Mikey Hawks's Avatar
Mikey Hawks
That's how I did mine thanks to those pictures. Worked out well.
To Help Needed - Installing Trailing Arm to Leaf Spring
