63 ignition switch/key
Old Nov 12, 2014 | 08:53 PM
Gene jockey's Avatar
Gene jockey
Default 63 ignition switch/key
I bought a replacement ignition switch from LIC (their part number 39-18A) with the thought that this unit might be a bit less easy to circumvent. I had a 63 converible in Houston while I was in college that was stolen 3 times and i got it back all 3 times! I figure I've used up my good luck.
I misplaced the installation instructions from LIC, but I got the original tumbler out with the paper clip. Are there any tricks for installation of the new unit? I noted a post about springs popping out of the unit.
Thanks in advance..!
Old Nov 12, 2014 | 09:03 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Since it's a '63, and many features are unique to that year I can't help you on the installation with any tips. I also don't think you have done anything to prevent anyone, even the most inept thief, from stealing your car. This is a very exciting subject that has been discussed many times here on the CF. Dennis
Old Nov 12, 2014 | 10:32 PM
Ironcross's Avatar
Ironcross
You can, if I remember correctly install the switch the same way you removed it...Paper clip in the tiny hole and turn the key all the way to the left on the switch and on the Vette...
you should see a 4 digit number group on the lock cylinder which is the key code....that group of numbers is used to cut some spares. GM keys havs 6 cuts....
To 63 ignition switch/key
