engine bay room/space
Old Nov 14, 2014 | 10:03 AM
legrand88's Avatar
legrand88
Default engine bay room/space
66 coupe - am contemplating using mid-rise intake manifold on my small block engine - is there air cleaner (stock) to engine hood clearance for this or do I need to re-think air filter options ? - Thx to all for taking the time to help !
Old Nov 14, 2014 | 10:17 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
What carb do you now have? The carb you use will dictate what air breather/element (stock or aftermarket) you use and that combined with your choice on manifold will play in the fit/clearance under the hood. This subject has been discussed before and may be listed in the "Sticky" section on the top of the page. Dennis
Old Nov 14, 2014 | 12:34 PM
legrand88's Avatar
legrand88
Holley
Old Nov 14, 2014 | 12:45 PM
65tripleblack's Avatar
65tripleblack
Originally Posted by legrand88
Holley
Your 1966 drop base air cleaner is the best that you'll be able to find. You might be able to put a Z28/LT1 intake on with no interference, but depending on body mount/shims use and condition, it will be VERY close. The interference point will be on the outboard edge of the air cleaner lid on the passenger side.
Use 4 putty or aluminum foil ***** placed on 4 points around the lid, gently close the hood and measure your clearance.
Edelbrock Performer should fit as well, but the Performer RPM will be too tall.
I used a Z28 for my build, and ended up adding shims to the body mounts to gain hood clearance.
Old Nov 14, 2014 | 05:17 PM
legrand88's Avatar
legrand88
Thank-you for your feedback
To engine bay room/space
By Michael S. Palmer | 2026-06-03 09:39:05
