MSD Atomic EFI
MSD Atomic EFI
I've been looking at the MSD Atomic EFI Unit. Spoke with the tech guy and downloaded the manual. Just wondering if any of you have installed one on your C-2 or C-3's.
The Unit looks very nice and can be used in many different configurations.
It only has an 8 wire connection set up. It bolts right to your intake and comes with a Mini Palm size set up unit that unplugs when your done.
List on the web page is pricey but It can be found at many big Suppliers.
Go to the web page below and their are videos on the site on the install as well as the Complete "PDF" manual for download.
Getting the itch... Mo Money ..Mo Money...
What do you think??
http://www.atomicefi.com/home.aspx If the link does not take you to the page ...look for Atomic EFI
What do you think??
Aesthetically they just sit up there and they don't look all that great.
The Benefit is a more accurate A/F Mixture and a Better running car with some HP Gains as well as a cleaner burn and not having to worry about Temp changes and fuel mixture changes in all weather conditions.
I drive my Vette on long trips allot in different weather conditions ware carbs show their lack of dealing with extream cold and or heat.
However ...I guess this would not be for every one who has a nice running local driven Vette. If it ain't broke don't fix it.
I can see that point. But their are Corvette guys who drive EFI Restomods that run extremely well.
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Sorry, I'm half asleep.
I thought you meant this.
Look into FAST EZ EFI. Most of these require a square bore intake, so factor that in to your cost as well.
Watch the video's their are three....
More...info...Looks simple... "If it looks to good to be true....." Is it
http://www.atomicefi.com/Quick_Start_Guide.aspx
Here's a thread wherein a Forum member tells of his good experience. There are others, too. The guy who installed Atomic EFI chimes starting at post #11
https://www.corvetteforum.com/forums...dding-efi.html
I'm intrigued by these systems, too. Atomic EFI and Professional Products Powerjection III are the only ones I know of which build the ECU into the throttle body, making for an easier installation. Some folks have been happy with the Prof. Products system and others have horror stories. I suggest you search this Forum and the C3 Forum for "Atomic EFI."
Steve
Steve
Steve
Thanks For the reply... I did check out the Pro Products unit but their system is not designed as well as the MSD. They say it doesn't need a return line ...but if you want to run it that way you need the more expensive by $300.00 and some dollar "Fuel Pump Speed Controller" which senses fuel demand and regulates the DC Voltage to the pump.
Plus when I spoke to them I had asked for some additional info which they provided after waiting several hours for a return call. Then I sent an email off asking for dimensions which I still have yet to receive.
The MSD folks seem to have a better web site with more info and better informed Tech staff that either answer on the first call or call you back with in a 1/2 hour or less.
Pus the install video was very helpful. The PDF Manual I down loaded is much less involved then the Pro Products unit. With theirs you have to use your laptop while driving and or standing still to fine tune the unit.
MSD's Palm Plug in is much more advanced. I'll check out the Posts on C-3.
Thanks For the info...
I use my Vette all year round even in the cold as long as the roads are clear and dry. Plus I take long trips. Just got back from Bowling Green for the 20 year anniversary of the NCM...2000 miles round trip.
Around town and speeds up to about 50 the A/F meter was around 13.9 to 14.1. But at interstate speed it was rich... Needs some work on the jetting.
Plus, changes in temp and humidity effected the mixture. I get tired of screwing with the carb. If it was all local I would just leave things be.
I installed Atomic EFI on my 67 Coupe in April, 2012 with MSD's distributor so timing is controlled as well. It is absolutely dependable and changes the way the car runs. Tuning is a breeze and can be done easily in real time. I opted to install the pump in my tank to make sure there would be no issues in hot weather. Initially I did the returnless system, but have since changed it to a return type using the original fuel line for the return. We have driven it over 20,000 miles since installation including a cruise from NY to Tahoe, CA with a drive to the top of Pikes Peak on the way. My car is totally dependable and predictable in the way it runs. On the highway I have hit as high as 21 MPG. I don't know if it has more HP, but throttle response is much more immediate and in the seat of my pants it feels good.
This August we relocated to cave Creek, AZ (I drove the Vette here) and had no problems in the 110 (plus) degree summer days.
For those who say it does nothing or is just an electronic carb, they are wrong! For best results get the distributor with it and mount the pump in your tank. If you would like information on how I mounted the fuel pump, etc. let me know. You can even use a stock GM dist cap and plug wires on this distributor and it will fit under the shielding.
Good Luck,
Roy
I looked at these for a while for my '67 Chevelle, by the time I was done adding up the full blown system (in tank fuel pump with return line, including timing controlled by unit, etc) it was approaching the price of a ZZ crate motor. I couldn't see it. I'm sure they work fine in the proper circumstances but the ROI to me wasn't justifiable. I fixed my carb/perc problems instead; but 'to each his own'
If people don't see an F/I 'rail' system I guess they don't think its F/I...I think that's a distribution issue and is a consideration...
OP, I wouldn't give up on the EFI just yet. The Atomic EFI is a throttle body FI (TBI) system, so it looks like a fancy carb, but it's not. GM made a gazillion TBI systems in the late '80s, they were dead on reliable and were easily able to meet emissions rules with a 3-way catalytic converter. You'll still need a good intake manifold. TBI systems need a good intake manifold so that fuel distribution between the cylinders is close to even. Port injection systems don't need that so much.
TBI offers a few advantages that the OP noted. It can control both the spark curve and the AF ratio to deal with all outside air and engine temps. They can be adjusted to give really good fuel economy at part throttle/light load. The closest you can get to that kind of adjustability is with a Quick Fuel carb with replaceable air bleeds in the metering block and in the carb main body - and at that it's still trial and error.
Will you make back the investment in saved fuel? No, not in this lifetime. Will you be happier that the car starts after just a couple of engine turns, runs perfectly without hesitation from dead cold to fully warmed up and gets 2-5 mpg better at part throttle. Probably.
A Carb is nothing but a partially controlled fuel leak. If you actually drive alot, keep in mind that the more precise fuel mixture afforded by these EFI systems most likely means less fuel wash down of your piston rings for longer cylinder and ring life, and cleaner plugs for longer life of those as well. I've got 205,000 miles on my 07 tahoe, with original plugs and it's not burning oil - try doing that with a carburetored motor
If I had the money, I would swap to the Fast Dual Quad setup, see pic, for my tunnel ram in a second... even though I already spent a sh*tload of time dialing in my carbs. I run my car year round, and actually have a winter jetting, and a summer jetting. Sure would be nice to drop that carb pullin, float bowl poppin, jet swappin, use these gaskets one more time, routine.
Hi Mark:
Good Luck,
Roy
Good Luck,
Roy
What you say makes sense...and this thread will continue like the others. But all I want is better A/F mixture and not worrying about playing with jets and carb tuning and all the PITA gack that goes with it. It might me just a Carb with Fuel Injectors in it but they run a hell of allot better A/F wise then any carb I ever seen.
The only thing that ticks me off is that they advertise it as returnless but then tell you your better off with a return line and or the pump in the tank.
I prefer the sequential port EFI systems. Pro-M, formerly mass-flo efi, makes a great system. Pricey, but it is truly plug and play. The last system i installed took about 8 hours, but after only setting the timing, i was out driving the car the next day and I didnt need to make any major adjustments. It's a bit more expensive, but you wont have to pay somebody a boat load of money to tune your car when it wont run either.
http://www.promracing.com/pro-m-efi-...fi-system.html
