Horn problem
Old Nov 24, 2014 | 04:05 PM
msk914's Avatar
msk914
Default Horn problem
I reattached my steering column in my 65 convertible today after replacing/fixing a lot of stuff in the cluster and then getting a new turn signal switch to replace the broken one in the steering column. When I put together the new switch on the column, I tested the horn by shorting the ring in the switch to ground, the horn blared. Good.
But when I put the whole thing back together, argh, the horn does not work. I believe all the parts were put back, but I likely missed something or put something in wrong. Here is a picture of the horn ring and then one of the steering column with the horn ring off:
First, it seems to me that the little bracket on the horn ring should always touch the part attached to the steering column (the little button); and that should touch the ring down at the switch below. But I think neither of those parts touch anything. What part am I missing, or did I assemble wrong? It seems to otherwise be perfect..
thanks, as always,
Mark
Old Nov 24, 2014 | 06:15 PM
65GGvert's Avatar
65GGvert
Here's some info: Scroll to the last picture, your hub appears to not be aligned with the mark, but I can't say what's up without seeing it better
http://www.lbfun.com/warehouse/tech_...Components.pdf
I can't tell what position your wheels are in, but my recollection is with the wheels straight, the horn button is around 2 o'clock.
Old Nov 24, 2014 | 06:24 PM
msk914's Avatar
msk914
Thank you. With my wheels straight, the horn button is at 10 o'clock more or less. That is probably the problem.
Mark
Old Dec 11, 2014 | 03:12 PM
msk914's Avatar
msk914
Mark
I fixed the hub, but the steering column was not far enough in, so the horn did not make contact. It is fixed now. Thanks for your help.
To Horn problem
