Keisler 5sp
I have one in my '61. Here is its description on the sales invoice:
TRG-RO5009A, KEISLER PERFECT FIT 600HP/600FT-LB 5-SPEED
TRANSMISSION ASSEMBLY, INCL: KEISLER CUSTOM BUILT TKO-600 WITH
LOW PROFILE INTERNAL OFFSET SHIFTER, MINI-BILLET SHIFT TOWER
WITH SPECIAL 2-BOLT LEVER, 4616 CHROMOLOY GEAR SET, 1PC
COUNTER SHAFT, DUAL SPEEDO OUTPUTS, REVERSE & NEUTRAL
SWITCH OUTPUTS, 99LB WEIGHT, RATIOS: 2.87, 1.89, 1.28, 1.0, 0.64
Beyond the shifter setup I'm not sure how much "custom" work was done...or if this description includes regular 'ole Tremec off-the-shelf features.
How is the shifter for the other brand tremecs different?
Here are pictures of the HURST modification to move the shifter to the left.
http://www.hurst-drivelines.com/?p=106
http://www.hurst-drivelines.com/?page_id=897
American Powertrain is slightly different yet.
http://americanpowertrain.com/images/F100483344.png
http://americanpowertrain.com/i-8521...-corvette.html
If you are between American Powertrain and Hurst Driveline Conversions, go with Hurst. The Hurst shifter sits lower and you can actually get a stock shifter boot over it. Also, American Powertrain has some really crappy employees. I was treated like garbage by them two years ago when I had issues with one of their 5 speed tremecs and therefore Hurst Driveline Conversions gets all of my business now. Another bonus is that Hurst generally keeps the transmissions in stock and does not build to order.
