Would someone mind telling me if I have the 65’s sunvisors on the right sides? They will go on both ways and the only reference I could find was in the shop manual. It does not show an image of the visor itself but the bolts that hold it together are different and you can tell from the diagram which one goes on either side. The left one is original so I installed it per the manual.
I know this may seem to be a trivial matter but I am about to cut a hole in the left one to install the lcd screen from a secret audio tuner and I want to make sure I cut the hole in the right one (or is that left one)!
