65 conv. side window removal
Old Feb 1, 2015 | 05:25 PM
vettjam's Avatar
vettjam
Default 65 conv. side window removal
When I removed my side windows from my 65 conv. I had to remove the upper stops in order to get it out. Was this correct or is there a trick to getting them out without removing these stops?
Thanks.
Old Feb 1, 2015 | 07:41 PM
65hihp's Avatar
65hihp
pretty sure those must be removed. I did on mine when I had to disasemble my windows to re-bed the panes in the sashes. They are easy to take off and put back on.
Old Feb 1, 2015 | 08:31 PM
Boyan's Avatar
Boyan
Default Window
Yes, the stops need to be removed. No big deal.
Boyan
Old Feb 5, 2015 | 10:26 AM
vettjam's Avatar
vettjam
Thanks for the replies. The Shop Manual does not mention that the stops have to be removed. That is why I thought there might be a trick to getting the window out without removing them. I removed mine and the windows are out.
Old Feb 5, 2015 | 03:13 PM
65hihp's Avatar
65hihp
you're doing good jammer.
If each and every sub-process was described in shop manuals, you would need a dolly to carry the manuals around.
To 65 conv. side window removal
