Distributor Break Plate - Source needed
Old Feb 4, 2015 | 07:51 PM
jkinton's Avatar
jkinton
Default Distributor Breaker Plate - Source needed
So the electronic ignition kit that was on the car came apart. I don't know if it was Bubba's fault, but considering the only electrical mod I've made is installing Detroit Speed headlight motors, I'm blaming him.
The pic is the aftermath. I'd be curious to know if anyone has seen something like this before.
In any case, I got a new kit to replace the damaged one, but one of the other casualties was the distributor breaker plate. It got bent pretty badly when things came apart.
I am having a tough time finding a source. The only place I've found is back ordered for at least two weeks.
I may get out the hammer, and try to straighten it, but I'd like to replace it if possible.
Does anyone have any ideas?
If it's not a forum vendor, please pm rather than post.
Thanks!
John
Old Feb 4, 2015 | 08:22 PM
66jack's Avatar
66jack
What brand of Dist is it?
Old Feb 4, 2015 | 08:55 PM
jkinton's Avatar
jkinton
The distributor looks factory, with a PerTronix electronic ignition conversion kit.
Here are some photos of the breaker plate.
Old Feb 4, 2015 | 09:10 PM
troutster71's Avatar
troutster71
From: Albuquerque Resistance is not futile. It's voltage divided by current.
Default Find a used distributor
If you are still running your stock Vette dist, a breaker plate from a stock chevy, non Corvette point dist MAY fit. I would think you could find one for about $15 bucks.
But then it is 2015, and you cant just run down to the corner gas station and look in their pile of stuff in the back room!
That's my idea, sorry if it doesn't help.
Cheers, Gary
Just saw the pics of the breaker plate, just clean it up, make it flat, and make sure the screw fits. You took the Dist out and apart, you can fix the plate! Go for it!
Old Feb 4, 2015 | 09:41 PM
LouieM's Avatar
LouieM
Try Dave Fiedler; he restores and converts distributors for a living and is an NCRS member:
http://tispecialty.com/
He completely rebuilt my stock 67 Vette distributor.
Old Feb 4, 2015 | 10:02 PM
jkinton's Avatar
jkinton
Cheers, Gary
I'm probably going to try to fix this one. I'm less worried about getting the tang flat than I am in getting that cylindrical flange round again.
I also think using a breaker plate from another GM vehicle would work. But even when I do broad searches at the various auto parts supplier websites under "distributor parts", I'm not finding anything that looks right.
Old Feb 4, 2015 | 10:03 PM
jkinton's Avatar
jkinton
Thanks. I'll check it out.
Old Feb 4, 2015 | 10:26 PM
Powershift's Avatar
Powershift
Checkout Long Island Corvette Supply #48-15. I think this is what you want. Google the name for website info.
Larry
Old Feb 5, 2015 | 06:25 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
No, I've never seen a Pertronix conversion cause damage like that. I don't see how it grenaded your distributor unless the module came loose - even then that breaker plate damage seems excessive in that case. I did have my rotor screws come loose once and knock the side out of my cap and I managed to limp home with only an occasional "miss".
Old Feb 5, 2015 | 07:13 AM
MikeM's Avatar
MikeM
That's a common breaker plate used in all Chevy V8 distributors from '58 up through and probably way past the early '70's.
I can't tell where yours is bent but if it affects locating the breaker points or the movement of the vacuum advance, I wouldn't recommend it.
Old Feb 5, 2015 | 02:00 PM
65tripleblack's Avatar
65tripleblack
Pertronix II is a great system, but I don't like the design of the rotating pole piece. If you have one of these installed, you had better be sure that your shaft end play is not more than about .015", otherwise the result can be much like a hard disc crash on a computer. If end play is excessive, the rotating pole piece will eventually drop down and rub on the pickup which will lead to eventual failure.
If you don't need the high voltage cacability of the Pertronix trigger, then the M & H (Breakerless SE) is MUCH more robust. If you need the high voltage capability, then use the Pertronix III which is a much better design.
BTW, that breaker plate can be easily straightened. The annulus around the shaft is not as critical as the points mount. Be sure to braze the ground wire back in place.
Old Feb 5, 2015 | 03:20 PM
JohnZ's Avatar
JohnZ
Clean it up, flatten the bent area, and re-use it (if the screw threads are OK).
Old Feb 5, 2015 | 10:32 PM
scnc4's Avatar
scnc4
If you still need a plate send me a PM with your address and I will send one in the mail
To Distributor Break Plate - Source needed
