blinker help
Old Feb 8, 2015 | 06:29 PM
cdub327's Avatar
cdub327
Default blinker help
My 67 roadster suddenly has no blinkers.Had steering wheel off to fix horn,they worked fine before,did not mess with switch at all. All bulbs are good,brake lights work fine,I swapped flasher with new one still ng.They work if I manually move directional arm up or down. I put test light to flasher plug in panel one leg lights it the other does not.Any tips or tests anyone can suggest.
Old Feb 9, 2015 | 05:01 PM
c1j1c2's Avatar
c1j1c2
St. Jude Donor '10-'11-'12-'13-'14-'15-'16
I had some weird problems with my lights when I got a crack in my plastic fuse block under the dash. Maybe a thought?
Old Feb 9, 2015 | 05:06 PM
JohnZ's Avatar
JohnZ
Originally Posted by cdub327
My 67 roadster suddenly has no blinkers..They work if I manually move directional arm up or down. I put test light to flasher plug in panel one leg lights it the other does not.Any tips or tests anyone can suggest.
Don't understand the problem - they work, but they don't?
The turn signal flasher doesn't go in the fuse block - that's for the hazard flasher. The turn signal flasher is mounted in a clip at the top of the driver's side radio side panel.
Old Feb 9, 2015 | 10:33 PM
cdub327's Avatar
cdub327
Thanks so much, my 1st Vette, learning as I go,love this forum
To blinker help
