Fire Extinguishers
Old Feb 18, 2015 | 06:58 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Frankie - what is the make/model on that unit used in your '61?
I tried to fit my existing unit into the glovebox, and while it would fit, it was so tight that I was afraid I would be unable to remove it in the fog of battle..... It sort of wedged in there and got stuck... bad news.
Old Feb 18, 2015 | 10:30 PM
mcb55-210's Avatar
mcb55-210
Originally Posted by Tearloch
I have seen people put them in the center console on C1s, but I was not comfortable with that. It was awkward to get in/out, and I was afraid in an emergency it would cause unwanted delay.
I found what I think is a great location. I mounted my extinguisher on the floor outboard of the driver seat. There is actually a large space there as the door slopes away from the driver as it goes down. It fit great, and is not an issue getting in/out of the car. Plus, it is right there in case I am bailing out of the car in a hurry.
Same location I use...hope I never need to use it, but will be handy if I do.
Mike
Old Feb 18, 2015 | 11:12 PM
63redvette's Avatar
63redvette
St. Jude Donor '14
Originally Posted by 65 vette dude
Yep.......that's why I have 2 Coldfire extinguishers, one behind each seat.
Ditto...oil/gas/plastic car = more is better! Two extinguishers always
Old Feb 19, 2015 | 07:39 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Amerex 344. Its Halon and may not be available now. If its available in Halitron it might be bigger as that mixture is only 1/2 as effective as Halon. The 344s do come up on eBay/Amazon once in a while. The 344 will knock around in the seat separator compartment unless you put a rag or small towel behind it then its fine... I can have it in my hand and the pin pulled in 2 seconds - it won't get stuck...
No more powder-based extinguishers for me. On the one engine fire where I used my garage extinguisher it took a day of clean up to undo the mess...
On a carb fire, such as mine, the talcum like powder can get sucked down the intake and I've no clue what damage it would do. I managed to get the car shut down before this incident so nothing went in the motor...
Scary, scary event. I had shut the car off in the garage, started into the house and heard a slight 'pop' under the hood and went back to check on things; my "professionally" rebuilt front carb had a leaky fitting and the fire was right there.
If I had gone in the house without checking things out I don't want to think about what would have happened.
Old Apr 3, 2015 | 03:17 PM
ejboyd5's Avatar
ejboyd5
I've said it before and probably will again when another fire extinguisher thread surfaces - Using a dry chemical extinguisher will leave you with something to clean up; the other extinguishers, particularly in the hands of those with little or no experience in putting out fires, may well result in a total loss. I carry only dry chemical in my automobiles and boats.
