Complete electrical loss after engine crank
Old Mar 1, 2015 | 09:14 PM
Dubyajay's Avatar
Dubyajay
Navigator
Default Complete electrical loss after engine crank
My '67 didn't want to start and after multiple cranks (apparently one too many), I lost all electrical... Is there a fusible link that I fried or some sort of thermal cutoff? Felt the starter and she didn't seem to be hot, but...
Any thoughts?
She's a 327/300...
Old Mar 1, 2015 | 09:20 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
First is your battery good. Second check and see if you have 14 volts at the horn relay
Old Mar 1, 2015 | 09:27 PM
66jack's Avatar
66jack
Also, Check your firewall connections/plugs
Old Mar 1, 2015 | 09:36 PM
65GGvert's Avatar
65GGvert
Particularly the large red wire in the firewall connector plug below the master cylinder. That feeds all electrical to the inside of the car, (dash, ignition, etc). First, measure the battery voltage and check the connections on it.
Old Mar 1, 2015 | 09:41 PM
Dubyajay's Avatar
Dubyajay
Navigator
OK - I'll check all your input. Thanks.....
Old Mar 1, 2015 | 09:47 PM
Ironcross's Avatar
Ironcross
All the above replies are good suggestions...But check your ground connection
Old Mar 2, 2015 | 12:02 PM
Dubyajay's Avatar
Dubyajay
Navigator
Thanks, Guys...
Your help saved me...
She's back to working great!
Old Mar 2, 2015 | 01:01 PM
66jack's Avatar
66jack
Originally Posted by Dubyajay
Thanks, Guys...
Well, what was the problem...
Old Mar 2, 2015 | 01:10 PM
65GGvert's Avatar
65GGvert
Thanks, Guys...
After you ask for help, you should always post back the fix so others can find it in a search and so that those who provided the help will know if they were on the right track.
Old Mar 2, 2015 | 05:48 PM
Tiros's Avatar
Tiros
My money is on the firewall connector
Old Mar 2, 2015 | 05:52 PM
MaineDoc's Avatar
MaineDoc
Me too. I had a 62 Biscayne 409 that just died. Scared me into thinking that I had killed a super car. Pushed in the connector and all was well with the world.
Old Mar 4, 2015 | 12:37 AM
65GGvert's Avatar
65GGvert
Thanks, Guys...
Don't be one of those guys. Come back and post what you found.
Old Mar 4, 2015 | 07:05 AM
Dubyajay's Avatar
Dubyajay
Navigator
Sorry, Guys...
Thought I had posted what Fixed it, but apparently not...
Checked the firewall connector, the ground and the positive post. All looked good. Checked the voltage at the battery and it was less than 6 volts. Battery was less than 6 months old, so bad cell? No, when I started removing the connections to pull the battery when the battery quick disconnect broke apart in my hand. Closer inspection showed corrosion not visible from the outside. Checked the voltage directly from the post and she was better than 12. Put it back together without the quick disconnect and she jumped to life. Strange, because she cranked strong for 4 or 5 tries, than nothing - not even a click. Sure seemed like a fuse or thermal shutdown from a overheated starter.
Old Mar 4, 2015 | 07:09 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Did you have the knife blade or 'green ****' disconnect ?
Old Mar 4, 2015 | 07:11 AM
Dubyajay's Avatar
Dubyajay
Navigator
Green ****
Old Mar 4, 2015 | 07:23 AM
Frankie the Fink
Army
Green ****
I figured - some here will suggest that never happens with those connectors, or, that you are using a cheap, Chinesium version.
I've had two of those green **** do-hickeys fail (NOT cheap ones) due to corrosion and moved to the knife edge style - never a problem.
Glad you got going again...
Old Mar 4, 2015 | 07:29 AM
Dubyajay's Avatar
Dubyajay
Navigator
Thanks - me too - I'll try the knife edge style. My green **** wasn't cheap either.....
To Complete electrical loss after engine crank
Old Mar 4, 2015 | 07:48 AM
csysman's Avatar
csysman
Green ****
not a fan of the green **** --- blade is the way to go for me --- just my opinion ... I also have had issues with the **** style disconnect unless i took the **** completely off - i was never sure it was working (opening my door to make sure the dome light was off, at times was not till i continued to loosen the **** some more)--- with the blade I am
Old Mar 4, 2015 | 08:07 AM
W Guy's Avatar
W Guy
I always just leave the negative terminal loose enough that I can twist it off and lay it aside. When I put it back on I press down and twist it like a jar lid and it gets tight. No problems and everything looks as it should.
Verne
Old Mar 4, 2015 | 08:18 AM
MikeM's Avatar
MikeM
Verne
I've been known to do that a time or two myself.
