ignition switch
Old Mar 14, 2015 | 05:14 PM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Default ignition switch
What was the first year the Corvette used an ignition / starter switch with an aux position?
Old Mar 14, 2015 | 07:27 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
'63
Old Mar 14, 2015 | 07:29 PM
Captain Bud
Super!. I'll just replace my '60 switch with a '63 and wire the radio to the aux position. Thanks.
Old Mar 14, 2015 | 08:25 PM
65GGvert's Avatar
65GGvert
Are we talking "acc"?
Old Mar 14, 2015 | 08:27 PM
Captain Bud
Default Acc
That's right ! I knew AUX didn't sound right. So I need an ignition switch that has Lock,OFF, ACC, Run, Start
Old Mar 14, 2015 | 08:33 PM
65GGvert's Avatar
65GGvert
I don't know about 63 or 67, but 64,5,6 didn't have a lock position. Left for acc, middle for off, and right for run (and start).
Old Mar 14, 2015 | 08:37 PM
Captain Bud
Default Switch positions
I wasn't sure about lock either but I just assumed those did. All I want is a replacement switch that has an ACC lug and will accept the existing plug as my '60 switch has. I saw something on the forum that gave a NAPA part number that did what I wanted but I can't find it.
Old Mar 14, 2015 | 08:55 PM
jim lockwood
'63s do have a LOCK and an OFF position.
On a '63 you can remove the key from the ignition switch once it's in the RUN condition and then rotate the switch between OFF, RUN, and START with no key at all.
To rotate back to the LOCK position, though, the key is required.
Note/Caution: When the ignition switch becomes sufficiently worn, it's possible to rotate the switch to the ACC position and remove the key. What's the big deal? In the ACC position, the gauges are powered up and will, given enough time (a few days), discharge the battery.
So you have to be careful with '63s "of a certain age" to be sure that you rotate the key no further than the LOCK position before removing the key.
Jim
Old Mar 14, 2015 | 08:58 PM
Captain Bud
Jim, thanks. Now to find one. It shouldn't be too hard. Step 1...open wallet. Step 2...wait for the mail.
To ignition switch
