59 front disc conversion
Old Mar 17, 2015 | 09:04 PM
wcotton@bathfitter.c's Avatar
Default 59 front disc conversion
I am curious to know if is there any way to convert to front wheel disc brakes on an original 59 and still maintain the stock rim and hubcap look?
thanks
Wayne
Old Mar 18, 2015 | 12:18 AM
John S 1961's Avatar
John S 1961
disc brakes dont change the wheels
Old Mar 18, 2015 | 08:22 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
My '61 has stock wheels/hubcabs and front discs from a '73 Camaro - can't help on the details - the conversion was done by a previous owner. It DOES also keep the original master cylinder and has NO proportioning valve. Works perfectly.
Old Mar 18, 2015 | 10:54 AM
thanks - for some reason i thought if you went to disc you were not able to keep the original wheels
Old Mar 18, 2015 | 11:16 AM
Frankie the Fink
Army
Prob depends on what equipment you use for the conversion.
On my '66 Mustang conversion I had to grind about 1/8" of each caliper to clear the wheels. No biggee...
Old Mar 18, 2015 | 11:57 AM
Vette Daddy's Avatar
Vette Daddy
We recently used the front disc conversion from Corvette Central. Really nice setup.
Old Mar 18, 2015 | 12:13 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
IF you were to use the 65 & up 4-piston calipers you would have to change to disc brake wheels.
Bill
To 59 front disc conversion
