65 engine stamp
Old Mar 18, 2015 | 10:13 AM
Cowtown Dave's Avatar
Cowtown Dave
Default 65 engine stamp
I have a friend looking at a 65 conv. He is being told it is the original block, although there are some engine parts that are not original that I was able to determine. Does seem like it would be original?
870 block cast date k254
engine stamp 5104552 FI204HF
300hp 4speed.
Old Mar 18, 2015 | 10:33 AM
JRRHINO's Avatar
JRRHINO
Any chance you could get a picture of the stamping?
Old Mar 18, 2015 | 10:55 AM
desertpilgrim's Avatar
desertpilgrim
In the assembly stamp, is the "1" a one or a capital I?
Old Mar 18, 2015 | 11:31 AM
Cowtown Dave
He didn't get a picture of it but says it looks like a lot of them that he saw online. He said the 2nd set was FI204HE (not HF, my mistake). So the "I" seems right
Old Mar 18, 2015 | 12:12 PM
JRRHINO's Avatar
JRRHINO
Without seeing it the stamping could be both original or a correct re stamp the broaching marks on the pad are the toughest part to fake.
Old Mar 18, 2015 | 01:14 PM
Vet65te's Avatar
Vet65te
Dave - As already mentioned, if you or your friend can supply us with some clear up-close pics, you'll get a lot of help from the Forum Members. As to the HE designation, that's listed as the base 250 horse engine with Manual Trans, the HF was listed for the next option up, the 300 horse 327 also with Manual Trans. Here's the front stamped pad from my 65 300 horse Coupe, the VIN is just a bit before the roadsters VIN.
Mike T - Prescott AZ
Old Mar 18, 2015 | 03:02 PM
JohnZ's Avatar
JohnZ
300hp 4speed.
If the car's VIN (below the glove box) is 194675S104552, it's probably the original block; the block casting date, engine assembly date, and the car's assembly date all line up normally. Not many folks go to the trouble of restamping base engines.
To 65 engine stamp
