C1 Headers
Old May 1, 2015 | 08:47 AM
bd hbt's Avatar
bd hbt
Default C1 Headers
Does anyone make C1 headers that don't require minor alterations to either the car or the header to make them fit properly? In my search, I haven't found any that are true "bolt on". I always see comments such as "modify frame flange", "grind header collector flange", etc. Heads are standard Chevy - no angle plugs.
Old May 1, 2015 | 08:50 AM
stratplus's Avatar
stratplus
My Hedman headers 68136, were a bolt on in a 60 with a 327.
Old May 1, 2015 | 10:51 AM
grumpy10956's Avatar
grumpy10956
hi , I have a ancient set of Hookers that Santa bought me they were drop ins on my 1961
Old May 1, 2015 | 11:11 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Hedman here too, on two Corvettes. Fit right out of the box. Still made in 'Merica.
Old May 1, 2015 | 11:25 AM
narlee's Avatar
narlee
I don't think Hedman makes C1 headers anymore. Might find some good used ones.
Old May 1, 2015 | 11:29 AM
vetrod62's Avatar
vetrod62
They have not made Hedman headers for C1 corvettes in about 5 years. They are the same headers I run in my black car. They are they only true header that advertises that they will fit angle plug heads. What heads are you using??
I do have new, un-used set of Hedmans that are coated. Jim
Old May 1, 2015 | 12:47 PM
bd hbt's Avatar
bd hbt
The car is a 62. Heads are standard Chevy, 2.02 intake, 1.60 exhaust, no angle plugs.
Old May 1, 2015 | 01:08 PM
GCD1962's Avatar
GCD1962
My Hedman required notching the drivers side frame
Old May 1, 2015 | 01:14 PM
bd hbt's Avatar
bd hbt
Yep. That's what I'm trying to avoid. The car had headers on it (unknown brand) and the upper frame rail flange on the passenger side looked like someone used a hacksaw and meat cleaver to "notch" it for header clearance. That just got repaired. I may need to stay with 2.5" exhaust manifolds to avoid the frame mods.
Old May 1, 2015 | 11:37 PM
vetrod62's Avatar
vetrod62
I have been putting headers on C1 vettes for 50 years, never had to cut the frame. No one has stated whether or not the cuts to the frame were for left to right clearance or clearance to hook up the remainder of the exhaust system. If the latter, that is just a lack of fabrication skills. None of the current headers will dump even with the exhaust holes in the frame. You have to off set your pipes to either go through or under the frame.
With your straight plug heads, the Hooker Comps and Super Comps will have a problem with the stock starter. If you are using a Mini starter, no problem. The thing with " 10.4" flywheel " is BS with the Mini starter.
The Hedman 68136 headers are the most versatile headers I have found, fitting evey angle plug head I have tried. All others work on some , but not on others.
Pictures of some of my headers.
Old May 3, 2015 | 07:38 PM
tangel2's Avatar
tangel2
I have Hooker super comps on my '58. They fit no problem but as others have noted, Hooker says they won't work with angle plug heads. Send a PM to Rickw001, if I recall he found currently available "Headers by Doug" (different from Doug Thorley) that will fit angle plug heads.
Old May 5, 2015 | 01:38 PM
Promotive's Avatar
Promotive
I have Hookers on my 59. I bought them from Summit. They fell into place, perfect fit.
Old May 5, 2015 | 02:49 PM
Vet65te's Avatar
Vet65te
When I bought my 61, I found that the Hooker Comps made this annoying screeching sound when the drivers side collector rubbed against the lower flange of the frame rail. A little grinder work helped to gain some clearance and still seals well. One other thing to mention, I believe the reason the Hooker headers were so close to the frame was due to their efforts to leave enough room for the oil filter but I found it was a bit tight to use a filter wrench so I've gone to the K&N types that have the hex protrusion on the bottom.
Mike T - Prescott AZ
Old May 5, 2015 | 02:55 PM
autoonero's Avatar
autoonero
Default headers
Jim,
I interested in your headers if you still have them.Please pm me back.
Thanks,
Larry
To C1 Headers
