headlight rotation problem
Old May 5, 2015 | 07:13 PM
batman1414's Avatar
batman1414
Default headlight rotation problem
64 corvette I have replaced the motors on both units but the passenger side one has been doing this. It works two or three times, then stops.
I then have to loosen the manual thumb screw to get to come up again.
and it works for another 2 to 3 times. anyone have any thoughts on problem?
Old May 5, 2015 | 07:18 PM
jdk971's Avatar
jdk971
make sure the switch contacts are clean. jim
Old May 5, 2015 | 07:27 PM
RK-TECT's Avatar
RK-TECT
Hi batman,
Are the motors new or old replacement motors? Has the grease been replaced? If not, the old grease gets very thick over the years and creates the problem you are describing. The problem can also be an electrical contact issue as Jim mentioned, but look into the grease first. Been there... done that!
, Roger
Old May 5, 2015 | 07:43 PM
batman1414's Avatar
batman1414
Originally Posted by RK-TECT
Hi batman,
, Roger
both motors are brand new
Old May 5, 2015 | 07:52 PM
Bowtyeguy's Avatar
Bowtyeguy
Sand and clean the ground wire connections and make sure both sides are clean and tight.
Old May 5, 2015 | 07:55 PM
RK-TECT's Avatar
RK-TECT
Batman,
I assume you didn't have this issue before you replaced the motor. If that's correct, then I would clean the electrical contact and make sure it and the ground are tight. If the issue persists, then I would think it's an internal issue with the motor and would ask the vendor to replace it under warranty. Let us know how it goes.
Good luck, Roger
Old May 5, 2015 | 08:20 PM
wombvette's Avatar
wombvette
Gear inside the motor is jamming. Are the the Chinese motors??
Old May 5, 2015 | 08:22 PM
66jack's Avatar
66jack
Did the buckets move freely when the motors were not on/attached?
If not, check the outboard headlight pivot shaft, it is not easy to get too....you might have to loosen the collar to adjust it so the buckets move without binding...
Old May 5, 2015 | 09:23 PM
batman1414's Avatar
batman1414
No I didn't have problem before changing out the motors.
Old May 6, 2015 | 07:49 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I don't know of anybody making "new" original-style motors; unless you got NOS motors.
If they are rebuilt then somebody may have tried "flipping" the main gear 180* instead of replacing it. That works about 3 out of 5 times. If its galled enough it'll eventually hit an ugly spot and affect operation... Or they may have mis-adjusted the preload.
Old May 6, 2015 | 08:57 AM
batman1414's Avatar
batman1414
got it from Corvette Central said it was new so assuming not rebuilt. seems strange that it works a few times perfectly then seems to lock up , but when I turn the manual raise/lower screw it works again
Old May 6, 2015 | 09:19 AM
Frankie the Fink
Army
That really sounds like a preload or gear problem....assuming the buckets aren't binding. With the motors out you should be able to 'flip' either headlight bucket up/down with a slight push of a finger. You can bench test the motors while they are out.
Checking the connectors forward of the hood for corrosion/looseness is a good idea too.
Old May 6, 2015 | 11:25 AM
Pilot Dan's Avatar
Pilot Dan
There's your answer if turning the wheel is needed to unlock the motor, and yes they do make Chinese versions of these motors which are not very good from what I hear.
Old May 6, 2015 | 11:46 AM
66jack's Avatar
66jack
If Corvette Central will take them back and credit your account....
I would purchase these if you not looking for NCRS correct, but want something that works when you want them too...
I have them as do a lot of others here on the Forum and they work flawlessly cost less than Originals....
http://www.detroitspeed.com/1963-196...rical-pg1.html
Old May 6, 2015 | 11:55 AM
Frankie the Fink
Army
I use the Detroit Speed kit too. An early version; I'm told that some aspects of the kit have changed with the later units....
Old May 6, 2015 | 12:38 PM
domenic tallarita's Avatar
domenic tallarita
I had mine do that as described in post 8 & 12. They worked well till I installed the motors I rebuilt. Put new gears in the motors along with brushes and turning the com. The motors tested great and the buckets moved freely til I put the motors on. one worked good and the other was slow.
I found the slow one rubbing the body after I adjusted the bucket to center. If I move it to one side it worked fine. I removed the bucket and sanded the area it was rubbing, repainted and all was fine.
Dom
Old May 6, 2015 | 06:42 PM
JohnZ's Avatar
JohnZ
Where were they made? There have been reports that the new "reproduction" headlight motors, made in China, are junk.
Old May 6, 2015 | 06:56 PM
rich5962's Avatar
rich5962
Just a thought, if the ground screw in that motor is just a tad too long, it can touch the field winding, short out, and cause a inop condition.
I had a intermittent once and the screw was too long in one of my '63 motors. Drove me crazy until I realized the screw was intermittently shorting out inside.
Pull the ground screw and check it's length, and make sure you have a external toothed washer between the case and the ground lug. Also no paint on the case under the washer.
The ground screws are very short....
Old May 7, 2015 | 06:56 AM
Frankie the Fink
Army
I read about that somewhere -- worth checking out..
To headlight rotation problem
