Muncie shift linkage question
Old May 20, 2015 | 11:35 PM
zeeker's Avatar
zeeker
Default Muncie shift linkage question
Is this rod supposed to be bent???? What exactly does this set screw adjust......explain Please????? zeeker
Old May 20, 2015 | 11:37 PM
Vet65te's Avatar
Vet65te
Zeeker - The first answer is: no, it's not supposed to be bent. As to the set screw, it has to hold the reverse lockout rod in place otherwise, if it was loose and allowed the reverse lockout rod to extend upward, the lower section wouldn't be in place to prevent the shifter from going into reverse when you're trying for first gear. You should be able to flatten the rod and take that bend out and once it's straight again, push the lockout rod downward and tighten the set screw and you're good to go.
Mike T- Prescott AZ
Old May 20, 2015 | 11:58 PM
zeeker's Avatar
zeeker
Thank You for that quick response. Do I push the rod down as far as it will go and then tighten it up?...................zeeker
Old May 21, 2015 | 12:06 AM
Vet65te's Avatar
Vet65te
Yes. I have about 8K miles on my 66 Coupe since I did a pretty major body-on freshen up back in the early 90's and the other day noticed the shifter was feeling very sloppy and when going to first gear, found it was real easy to slide into reverse. Got it home and when I pulled the reverse T-handle, saw the rod had slipped upwards about a half inch, just enough to not provide adequate blocking so the shifter slid right into reverse. Pushed it down, used the right size Allen wrench and tightened it up, no problems since.
Mike T - Prescott AZ
Old May 21, 2015 | 12:18 AM
zeeker's Avatar
zeeker
Thanks Mike! That answers one of my multitude of questions..................zeeker
Old May 21, 2015 | 01:00 PM
JohnZ's Avatar
JohnZ
Here's what's at the bottom of the rod, and you can see how it locks out lateral movement of the shift lever into the reverse gate unless the rod is raised clear by the "T"-handle.
Old May 21, 2015 | 04:20 PM
zeeker's Avatar
zeeker
Thanks John. That picture's worth a thousand words.............zeeker
To Muncie shift linkage question
