Headlight Problems
Old May 21, 2015 | 01:04 PM
cwalley's Avatar
cwalley
Default Headlight Problems
The headlights on my 1960 have decided to give me problems. They will turn on and work fine, but after several minutes they will shut off. Then after a minute or two they will work again... and the cycle continues. The taillights and turn signals work fine. I have steady power into the switch (one year old and the wiring is all new. My guess is that it is a poor ground somewhere, but not really sure of a process for zeroing in on the problem spot. Any suggestions?
Old May 21, 2015 | 01:12 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
There is a thermal breaker in the headlight switch that 'strobes' the lights when there are issues; theoretically - that will let you see well enough to limp to a stop. Could be the switch itself or old wiring/corroded connectors...any of these items can overload the breaker. Headlights are not fused in the traditional sense.
If its a repro switch that could be an issue (you say your wiring is new) I've heard some of the repros are junk...
Old May 21, 2015 | 01:14 PM
62corvette's Avatar
62corvette
Frankie is right on. I'm guessing the switch is a reproduction. They are infamous.
Old May 21, 2015 | 01:18 PM
cwalley's Avatar
cwalley
Any suggestions on diagnosing the switch> Even if it was a repo, it was an expensive repo and electric parts are usually non returnable. I'd like to be sure before I buy another. Also, if I do, where should I go to get a reliable switch? Thanks for the quick replies.
Old May 21, 2015 | 01:24 PM
Frankie the Fink
Army
OK - are the headlights T3s, Halogens, or what ? Some of those light upgrades draw more current. Is ALL the wiring new...all the way from the switch to the 2 and 3 prong headlight connectors ? Does the problem occur on lo beam or just hi beam ?
Old May 21, 2015 | 01:31 PM
Frankie the Fink
Army
I like Zip or Paragon for parts.
Zip has a one year return policy with no restocking fee - there is nothing in their policy excluding defective electrical parts - I just read it.
Old May 21, 2015 | 01:46 PM
cwalley's Avatar
cwalley
Headlights are Sylvania Halogens, the wiring is entirely new and the switch was purchased from Paragon. Any diagnosis on the switch suggestions?
Old May 21, 2015 | 01:47 PM
cwalley's Avatar
cwalley
Just noticed I did not answer one question - when it goes down it is both high and low beams, but not any other electrical parts.
Old May 21, 2015 | 01:49 PM
Frankie the Fink
Army
The headlights are on a dedicated circuit and a malfunction there won't affect any other lights or other components.
Halogens aren't your problem and the new wiring seems to exonerate that as the issue. I think you got a bum repro switch and I don't know of a way to evaluate those; you'd have to simulate an active load and then determine if the thermal reset point is too low. I certainly have no equipment for that.
You have three options:
1) Add relays to the headlight hi-amp circuit and eliminate the switch carrying all of the load. Eckler's and Mad Electric sell the kits.
2) Return the switch to Paragon and roll the dice on another one.
3) Only drive during the day.
Old May 23, 2015 | 01:00 PM
cwalley's Avatar
cwalley
I have a fourth possibility. I once owned a 74 MGB (Lucus Electric!!!!!!!) and the headlights both went out one night. I went to the local Dollar store and bought two flashlights. Drove home with my girl friend standing over the windshield holding the flashlights. It worked with slow driving but it's kinda tacky. Think I'll go for the new switch.
Old May 23, 2015 | 01:57 PM
skip57's Avatar
skip57
check the ground side of the headlights. I think it is on the frame
Old May 23, 2015 | 02:21 PM
rtruman's Avatar
rtruman
I pretty sure that I know what it is,Think about this did it just give you problems or you just noticed it while driving at night
The quartz headlights are an up grade when you put both high and low beams on it draws more current and the breaker will open up that's how it works headlight switch is fine .
They make a kit that you have to use as an up grade it plugs into
dimmer switch on floor no splicing wires plug and play .
I did come directly of the battery with help from forum guys.
http://www.ronfrancis.com/prodinfo.asp?number=HR-56
Old May 28, 2015 | 10:11 AM
cwalley's Avatar
cwalley
Default Headlight issue
This posting gives me something to consider. I did replace teh switch and the headlights now work. But I wonder why a relatively new switch would burn out? So should I get this kit so that I'm not buying another new switch next year? T
Old May 28, 2015 | 11:10 AM
66RBS's Avatar
66RBS
Default Headlights
If you are using sealed beam halogens you are drawing about 13 amps thru the headlight switch (2.7 x2 + 3.9 x2). As others have said the repro switches are marginal in handling this load.
Headlight relays also offer the advantage of brighter lights due to less voltage drop at the sockets. Additionally they route some of the load off the headlight switch. The headlight switch would only control the relay coils a much lighter load. Power for the headlights is taken from the battery or horn relay buss. Check archives for more details
Randy
Old May 28, 2015 | 12:31 PM
rtruman's Avatar
rtruman
Yes , take the load off of light switch and the new harness wiring by running fused at battery #12 wire to in put at relay in foot well location . it was easy to tuck behind stock wiring on front engine bay. lights will be brighter and wiring protected for long run. This job should take 1 hour tops.
Old May 28, 2015 | 06:37 PM
Frankie the Fink
Army
The relays are indeed a nice upgrade, I made up my own kit and stuck the relays W-A-Y up under the windshield washer fluid tank. You would have to nearly do a headstand to see them from under the hood.
Do you know why I did this conversion in my '61?????
Because the repro headlight switch I bought started strobing the lights about the third time I used it....
Old May 28, 2015 | 07:01 PM
rtruman's Avatar
rtruman
That's funny you said that I did this with my first 63 in the first year the quartz headlights came on market.
I did my own relays and spliced into dimmer switch .Cant remember when they came on market anybody remember.
To Headlight Problems
